How Much Power with only bolt ons??
also if you go with the 1.8 rockers it will limit you in the future to what size cam you can use. so you might think about using that money to get a buget nitrous kit and this way you will definatly be way into the 11's.
You might hit high 11's with that setup, but if you do some suspension work, get some tires, and maybe a little weight reduction, you will hit 11's for sure, maybe even mid 11's...
btw, I guess I should have read the original post better, but the title says 'bolt-ons' so I guess I was thinking an ls6 or fast 90 intake was part of that...
