gain from ls6 intake to fast 78??
i have noticed with my experience with the fast 78/90 vs ls1,ls6 intake are there is improvements all the way across the rpm range as well as peak. But the one big thing that i have noticed between the 78 vs 90, is that the 78 stuff is alot more responsive down low than the 90's.
If the confusion is regarding which set-up to get (a 78 or a 90 mm unit), dont lose any sleep there because the right decision is easy....a 90 just flat out works better. Or should I say a properly shaped 90 mm TB (NOT a stock LS2 for the Vette crowd) such as a unit from Nick Williams for an F-Body, will experience zero loss of power or responsiveness when compared to a 78 and make more power in the upper RPM range. If you want it all just step into the FAST 90/90 set-up and be done with it....Yes a FAST 78 is a good piece but a 90 mm version of the same is worth 5 or so more upstairs (and usually gives better throttle response with the right TB....a stock LS2 is the worst and needs major work to improve its response AND peak power numbers so if you think a 90 isn't responsive you may have had some dealings with that particular TB.
Tony M.
Tony M.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Tony M.
Tony M.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Originally Posted by Benjamin Russick
How does the rest of the curve look? Does the 78mm stay with the 90mm up until stratopheric revs? I'm mainly looking at 5900-6400rpms where my LS6 intake just can't keep up. A good ported 90/90 set-up is well over $1K and that is just crazy to me. Hopefully, more alternatives will materielize as this price is crazy. If I get 20-25rwhp over the LS6, it might be justified, but 12-15rwhp? ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
A ported 90/90 set-up is usually worth about 25 over an LS6/stock TB....big money but sizable gains IMO. Its all a personal decision of how much you value that extra power. At roughly $75 per pony its actually not that bad all things considered....the porting while increasing the initial cost actually drops the $$ per HP figure...essentially makes it more of a cost effective mod if your willing to invest a little bit more.
Either way, ported or unported, the bottom line is most of the high power cars you see on this site and others run a FAST 90....its not a coincidence and its also not cheap....that's for sure.
Tony M.
I know I have come to the end of the road and I have asked my self certain questions do I want to buy this piece or that piece of Horse Power gains and either made the choice or not. So I think we have the information now that the 78 is better than the LS6 and the fast 90 is even better than the fast 78 and so the question is....do you want to take the red pill and follow the rabbit or not!
Who does FAST porting and do the heads need to be present for port matching? How much is usually charged for this service? If I got 25rwhp, the 90/90 wouldn't be so bad, but is that increase the exception or the rule. Thanks for everybody's help.
LS1 Tech Administrator
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
#32
Originally Posted by 383ss
years ago on my 383 I picked up 10rwhp going from an LS6 to fast 78 and then about another 5 going to the 90/90.
8-11 HP over stock....Ive done the test more than once and the results have always been similar.
I originally had a ported 78 FAST on my original 346 combo with the AFR 205's and our 224/228 cam.....when I made the move to the 90 mm version I only picked up about 5-6 HP
#34
Originally Posted by OhIt'sBeenBraughten
Tony, how much do charge to port the Fast 90?
PM me for more information if you like...
Tony
#35
#36
I'm a little late to the scene on this one but here goes.
How would a FAST 78 do on an otherwise stock cam/stock head f-car w/LS6? Ported 78? Money is not an issue. I'm curious as to the ported 78 over stock is.
I'm trying to maximize my bolt-ons potential because I can't afford the down time (not the price) of a cam at the time.
Also I plan stoker motor in the future (next summer hopefully) and it would be just another part I can reuse then. Besides all you need is the top shell of a 90 to upgrade to 90 later on right?
#37
You won't gain nothin unless you through a cam in there. There would not be a reason to port the 78 or for that matter run one unless you through a cam in there. If you run a nice cam such as one of the vengenance street cams or a custon edc cam and you are running full exhaust like QTP headers or AMR or Kooks headers with offroad x pipe or high flow cats you might see a 10 rwhp gain with the ported fast 78 over the ls6.
