AFR Heads/cam combo re-tuned....RESULTS INSIDE!
just watched your video. SWEET ! Looked like you did a good burn out, tires should've hooked a bit more. I noticed how they rushed you at the line. I mean as soon as you got there the tree was almost on green. I bet had you gotten about 3 or 4 seconds to get settled in you'd have nailed your launch and been in the low 1.7's for your first 60 ft and probably knocked 2-3 tenths off your time out the back end. Good luck !
Originally Posted by 02SOMWS6
Nice numbers. I just put down 452rwhp and 408 rwtq with stock bottom end ported 241 heads with a 12 bolt ,4.30 gears and a denny's heavy *** nitrous ready driveshaft
Originally Posted by zssman
whats the cam specs on that beast. 121 mph is killer. Is that on motor or spray.
