On the dyno are you richer or leaner than on the street?
Old 10-23-2006 | 06:53 PM
YO-EL's Avatar
Default On the dyno are you richer or leaner than on the street?
Does running on the street lean out or richen the A/F ratio, compared to when you're on the dyno?
Old 10-23-2006 | 06:57 PM
oange ss's Avatar
leaner on the street
Old 10-23-2006 | 07:43 PM
John02SS's Avatar
depends on the dyno. I own a dynojet 224xLC with the eddy loading system and I've seen a/f results VERY close to street pulls with the system loading appropriately. If the dyno can't load, then it will be leaner making street pulls. As much as .5.
Old 10-26-2006 | 10:40 PM
rotwiler's Avatar
Good question, I have been wondering the same thing. When I changed my a/f on a dyno I set it at 12.9:1, but then started thinking about weight and load differences. I may richen it up a little and see what results I get next year.
Old 10-27-2006 | 07:32 AM
gtodoug's Avatar
It really depends on the tune.
dougie
Old 10-27-2006 | 08:06 AM
dynocar's Avatar
This is why it is so much better to set up your fuel, timing, auto shift points, etc on a dyno, any brand, that can simulate your actual engine loads.
Old 10-27-2006 | 05:14 PM
gtodoug's Avatar
Ditto that dynocar.
Dougie
