PCV problems = Low dyno numbers?
Old Oct 26, 2006 | 03:29 PM
ws.6kid's Avatar
Default PCV problems = Low dyno numbers?
Would a PCV problem cause a car to loose power? like say 50 rwhp? My car is burning oil and smoking out the exhaust and I've narrowed it down to rings not seated, bad valve seals and or guides, problem with PCV system. I guess Im gonna just delete the PCV system and see if it stops smoking.
heres my other threads so you can understand whats going on...
https://ls1tech.com/forums/showthrea...37#post5768037
https://ls1tech.com/forums/dynamometer-results-comparisons/596979-forged-347-trex-heads-402rwhp.html
Old Oct 26, 2006 | 04:47 PM
black01_WS6's Avatar
try putting a catch can on there, but you have bigger problems than that. It sounds like the rings are fried.
Old Oct 26, 2006 | 04:55 PM
ls1408cp's Avatar
It could be your rings if you took it easy for the first 500 miles. My 408 on the dyno yesterday pushed alot of oil into my holding tank but the car had no miles on it. So I am sure if your pvc system goes to your intake you are burning tons of oil. I would change your pvc setup and then run the **** out of it or rent a dyno for a couple of hours and tear it up.
Old Oct 26, 2006 | 07:43 PM
1BAD02WS6's Avatar
if your tring to seat rings its best to get on the highway and bring the car up to 4500 and let it run agianst itself to 2500 a few times. this will creat a vacuum in the cylinders that help seating rings. all new motors should have this done.
Old Oct 27, 2006 | 08:12 AM
ws.6kid's Avatar
what make s a PVC system not work properly? Does this happen to cars with heads and a big cam?
