TFS/Comp combo results
Thanks go out to Mikey from Rapid for getting this all together and a great tune, and to Brian from TFS for working through the issues.
Parts List;
Stock Crankshaft - Polished
Stock Connecting Rods - Resized
Diamond forged Pistons with -2cc valve reliefs
Childs and Albert Ring Set Plasma Moly
Clevite H Series Race Bearings
ARP Rod Bolts
ARP Main Studs
APR Head Studs
Rotating Assembly Fully Balanced
Engine Blueprinted
Comp Cams 850-16 Roller Lifters
New OEM Lifter Retainers
Rollmaster Double Roller Chain
Trick Flow Research 215cc Cylinder Heads
Heads milled .024 for 61CC chambers
11.4:1 compression
Cometic Head Gaskets .040
Comp 230/230 113+2 .591 lift Cam
Trick Flow 7.65 Moly Pushrods
Harlen Sharp Roller Tip Rockers 1.7
Textrila Z grip clutch assembly
peace
