ALL New PRC Stage 2.5 5.3L Head Results!!!!
Old 11-08-2006 | 05:20 PM
  #41
Zach@Texas-Speed's Avatar
Originally Posted by tilly
What an interesting post. I am currently interested in a setup like this. Cant wait to see some numbers for this setup.
More should be on their way
Old 11-08-2006 | 08:12 PM
  #42
tilly's Avatar
You guys are goign to recieve a phone call from me, one of hese days, once I have the money to do the modifications.
Old 11-08-2006 | 08:53 PM
  #43
Dom's Avatar
Dom
So what's the biggest cam(approx) based on XE-R lobes(or similar, just not going with those huge LSK lobes) that you think will fit without flycutting?
Is the biggest advantage of 5.3 heads increased compression? What's the compression?
Old 11-09-2006 | 11:57 AM
  #44
The Torquer 3, 233/239 or MS3 will be the largest you can run with these heads. If I had my choice I would probably go with the torquer 3 for a little more midrange that it provides. All three cams will work fine though!!
Zach
Old 11-09-2006 | 12:12 PM
  #45
Dom's Avatar
Dom
Zach
Can you guys can make custom camshafts based on XER lobes? I like the specs of the Torquer 3, but I'm afraid to run those high lift lobes on my DD. I put on alot of miles on my car. Don't want to be going through expensive double springs until I get another DD.
Old 11-09-2006 | 12:15 PM
  #46
KingSS's Avatar
If you don't like the torquer v.3 then go with the torquer v.2 because its almost the same cam just using the XER lobes.
Old 11-10-2006 | 11:51 AM
  #47
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We also have the PRC 5.3l heads setup for the MS3 camshaft. They are special order with a little bit different setup valve depths, but with some extra time & tweaking they work very well! We have shipped all backorders on 5.3l heads! Give us a call if you guys need a set & I'll make it happen.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 11-10-2006 | 07:01 PM
  #48
blazeone's Avatar
Just missed you at the office. PM sent
Old 11-12-2006 | 03:15 PM
  #49
venom ws7's Avatar
great numbers cant wait to see what the FAST wil do
TSP all the way
Old 11-12-2006 | 06:46 PM
  #50
99WS7's Avatar
so how are these heads compared to the Terminator heads you have.
Those are some very nice numbers!!! Hurry up and get the 90 on!!
Old 11-14-2006 | 01:01 AM
  #51
OdessitPashka's Avatar
Amazing results! I need to start saving up!!!
Old 11-14-2006 | 03:39 AM
  #52
BOWTIE's Avatar
And what ever happened with those dyno test that were supposed to be coming out. I am going to be ordering a set of heads and cam package soon and have several of your options in consideration.
Old 11-18-2006 | 05:48 PM
  #53
Red99TA's Avatar
How about a normal dyno graph w/ power and torque vs. rpms? I'm interested in finally going with some heads!!
Old 11-21-2006 | 10:27 AM
  #54
Guys I still haven't been back to the engine dyno for testing. I'm currently holding out for a few more head configurations to get finished up! We recently had a 5.3l stg2.5 & 228 camshaft go 430rwhp through cats in a c5! I'll post that graph up very soon!
__________________
Jason
2005 Twin Turbo C6
Old 12-31-2006 | 12:54 AM
  #55
NHRAFORMULA00's Avatar
Still waiting on the DYNO of the FAST 90/90 set up.I ordered mine about 10-12 days ago.Im thinking of having it ported also.How close are those 26# injectors to being maxed out?Are you using an adjustable fuel pressure regulator on that car? Sorry for all the ?
Old 01-02-2007 | 07:49 AM
  #56
To The Top
Old 01-02-2007 | 09:50 AM
  #57
99reddevilFRC's Avatar
mine were supposed to be shipped this past thursday, cant wait to get them on. ive got a cam only vette that went 11.41 @ 124 w/1.81 60ft NA. these babys might get me in the 10s NA. more important to me ive got a couple blown cobras to f up. be nice to do it w/out the juice.
Old 01-02-2007 | 11:22 AM
  #58
cws T/A's Avatar
Dont forget the video camera
Old 01-03-2007 | 01:18 AM
  #59
chriswtx's Avatar
Old 01-03-2007 | 05:19 PM
  #60
bad6as's Avatar
for the tqer v.3 has a intake side of 231 with .643 of lift thats on a 111lsa is it also on a 111 icl?
i want these heads for a 227/232 lsk/xer on a 109+0
with 4* less duration and less lift but a lower icl would i have ptv problems?
Quick Reply: ALL New PRC Stage 2.5 5.3L Head Results!!!!
