Dyno with bolt ons 98 Z28
Old Nov 8, 2006 | 09:57 PM
srproductions's Avatar
Default Dyno with bolt ons 98 Z28
98 Z28 M6 w/75k miles
I had a bolt ons tune done at TTP in NJ.
Mods were as follows:
Kooks LT's with cats
SLP Loud Mouth
MTI Lid
Pulley
The car has a hypertech tune on it before, put down 335 before and 345RWHP after. No detonation and clean a/f which was no goal. They did a good job and I am happy with the numbers, now time for a cam
Are these numbers low, average, or high for my year and mods?
Old Nov 8, 2006 | 10:14 PM
SuperSport623's Avatar
damn.... 345 rwhp with just those bolt ons? not bad!
Old Nov 8, 2006 | 10:25 PM
NVR KNO's Avatar
thats really good. especially being a 98, i heard the 98's dynoed a lil lower then the rest. i have a 99 and i put 352/360 down with my cutouts closed and that was without a pulley and im on a stock catback too.
Old Nov 8, 2006 | 10:31 PM
98camaroLS1M6's Avatar
Strong numbers, no intake or TB? Congrats!
Old Nov 8, 2006 | 10:34 PM
Stock intake manifold and stock TB.
How much do you guys think I can pick up from an LS6 intake?
Old Nov 9, 2006 | 06:47 AM
Slowhawk's Avatar
LS1Tech Sponsor
Do you have the SAE graph?
Old Nov 9, 2006 | 09:59 AM
TTPMatt's Avatar
Don: I have the SAE graph here. You know as well as I do during our fall/winter time the SAE numbers are horrible. I dont 100% believe in the SAE numbers since it is a formula calculating what your car "should" make in those conditions. The uncorrected numbers are the true to life numbers that the car is making. Of course you post the UNC numbers on this forum and the pirahnas come out to bite your *** . I believe the SAE correction was 96%.
Old Nov 9, 2006 | 06:19 PM
NVR KNO's Avatar
from what ive seen, you should prolly pick up 9-12whp from upgrading to the ls6 intake. i would prolly port it before i install it though.
Old Nov 9, 2006 | 06:45 PM
Slowhawk's Avatar
LS1Tech Sponsor
Just asking so I can compare it to a 98 car we have here with the same mods
Old Nov 9, 2006 | 07:53 PM
TroubledWine3's Avatar
Not talking **** or picking a fight but when the majority go by SAE and use it to compare, you might get a request or two when the correction factor isn't used.
My 98 made 333/345 with the mods in my sig, but on the stock clutch(I imagine the non-slipping SPEC 3 and a way lighter flywheel picked me up a few at the wheels), would be interesting to compare it to the SAE numbers of this car.
Old Nov 9, 2006 | 08:17 PM
'Trust''s Avatar
Good numbers, M6 or A4?
There is no difference between the 98-00, 98's being inferior is a myth.
Old Nov 9, 2006 | 08:32 PM
Wrong, the computers on the 98 are different.
Old Nov 10, 2006 | 09:16 AM
NVR KNO's Avatar
i wasnt sure, i just know when ive seen a few of my friends dyno their 98's, they dynoed lower then all of us. it could just be the car too, but you never know.
arent the injectors bigger on the 98's too?
Old Nov 10, 2006 | 09:44 AM
Alvin's Avatar
The 98's have different heads too.
I don't think they are disadvantaged in anyway. I did a 98 cam only (ms3) that put down 418 SAE before a 9inch.
on top of that my 98 vette dynoed 325 SAE with a tune, catback, and vararam which doesn't help being stationary at all.
Old Nov 10, 2006 | 12:04 PM
Slowhawk's Avatar
LS1Tech Sponsor
98 heads are the worst.If you take them off and put stock 00 heads on you'll gain hp/tq.
Old Nov 10, 2006 | 09:50 PM
True, i know, 98 cam only car right here. Nothing like those 2002 241s.
Old Nov 12, 2006 | 01:41 AM
GoatRider's Avatar
At 345 hp and 354 tq, I'd say your results are amazing. I am still trying to figure out what I am doing wrong with my car. Mods are K&N cold air intake, JBA headers with high-flow catted midpipes, JBA 9MM ignition wires, GHL catback exhaust and dyno tune. The car is an 05 GTO automatic.
The tuner was embrassed by the results and I was shocked. Maybe I have a heat problem since the tuner said he could only advance the timing by 1 degree because of detonation. At 331 HP and 323 TQ, I am at a loss for words.
I think I will get another tune at a different shop. What else can I do?
Old Nov 12, 2006 | 06:48 AM
SideStep's Avatar
WHAT??? That is the reason we use a "standard" system for comparison is to control as many variables as possible vs. changes made to the platform... Otherwise you cannot truly isolate the differences between hardware changes or environmental impact...
Old Nov 12, 2006 | 07:36 AM
98SS2836's Avatar
I use SAE as a tuning tool. It's about the average weather up here anyways. Uncorrected number vary way to much to use for tuning on different days My car put down 480+ uncorrected I cant go by that though because if it's 90 out it probably makes 430.
But anyway nice numbers out of a 98 im sure your enjoying them.
