Stock Heads MS3 dyno numbers?
Old Nov 14, 2006 | 05:06 PM
RobbieTransAm's Avatar
Default Stock Heads MS3 dyno numbers?
Anyone that is still using stock heads and has the MS3 cam, please post your dyno numbers. Thanks.
Old Nov 14, 2006 | 05:32 PM
KingSS's Avatar
My car made 400rwhp with stock heads and ls1 intake manifold.
Old Nov 14, 2006 | 05:45 PM
camscam02's Avatar
in the sig! no ported throttle body or underdirve pulley! in a stalled auto!
Old Nov 17, 2006 | 05:31 PM
radz282003's Avatar
Are those cams just light in the torque. I noticed in GMHTP that the MS4 was pretty light in the torque, too. Well, that's not to say there's something wrong with 400 RWHP...
BTW, funny seeing you here Cam ;D
Old Nov 18, 2006 | 12:24 AM
camscam02's Avatar
yea it is funny chuck! ummm yea this cam is a low torque producing cam! but high HP!
Old Nov 24, 2006 | 12:53 PM
AlexLS6's Avatar
I made 443.3 RWHP/395.7 RWTQ open cut-out,
closed was 430.5 RWHP/386.0 RWTQ all mod are in my sig.
DYNO SHEET
Old Feb 28, 2007 | 02:26 PM
347fairless's Avatar
DYNO SHEET
I called the shop in Quebec to ask about getting a tune for an MS3, and they said your running an LS6 head. That true?
Old Feb 28, 2007 | 04:54 PM
mmorrison09's Avatar
I made 455rwhp and 405rwtq on stock heads with my ms3
Old Feb 28, 2007 | 08:24 PM
HOSS's Avatar
Dyno sheet?
Old Feb 28, 2007 | 09:23 PM
CaliboyTA's Avatar
my friend hit 448rwhp 408rwtq on his 02 corvette z06 on a slipping clutch. stock ls6 heads, stock intake, ms3, lg longtubes, off road x-pipe, stock ti exaust, custom tune. dyno was taken on a dynopack
Old Feb 28, 2007 | 09:32 PM
HOSS's Avatar
Thats pretty good. I was asking for his dyno sheet, b/c I have never seen a cam only ls1 break 400 tq. I was just curious if that was STD Correction or not.
Old Feb 28, 2007 | 10:31 PM
CaliboyTA's Avatar
it was sae corrected. Remember its a z06 so it has ls6 heads and there is a debate that dynopacks dyno higher then the dynojet. My friend dyno tuned his z06 on a dynojet and he put down 430rwhp 390rwtq. Only different between that dyno and this dyno was that he changed out the plugs and wires
Old Feb 28, 2007 | 11:00 PM
Dyno sheet?
I dont have one but SQR has it at the shop. oh and this is with stock 243 heads as well.
Old Feb 28, 2007 | 11:16 PM
ls1muscle's Avatar
Wow, some of you guys have some really really really friendly dynos. Makes for happy customers though
Old Mar 1, 2007 | 01:05 AM
HOSS's Avatar
Yea, I knew that. I was referring to the other one. Thanks though
Morrison, I am not saying you are lying or anything, I just want to know the correction factors. My STD correction for mine was 438/401, but SAE was 430/393..above 400 rwtq is a first as far as a know for an LS1 that is cam only SAE
Old Mar 1, 2007 | 01:24 AM
bad95killer's Avatar
377rwhp/351rwtq SAE Corrected stock heads + MS3 thru an A4
peace
Old Mar 1, 2007 | 05:29 AM
I will have to stop back by the shop and find out what the SAE was.
Old Mar 1, 2007 | 06:37 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Even though my nearly stock 02 non ram air t/a with a flow pac make 346 rwtq, its a lil peaky due to stock tune, I am sure MS3/MS4 guys with tune make more torque in the lower end then mine.
330 rwtq from 3600 rpms to 346 at 4600, but then a friend with a cam and tune (mild ESP1 cam) did a might flatter curve, with a peak of 374 at around 4,700.
Either way any LS1 needs to have a high stall launch, so if you leave at 4-5k then who cares about the soft tq curve. That rpm will only be used for 1 gear, then your in the meat of the cam.
Old Mar 1, 2007 | 04:06 PM
SIC LSX's Avatar
i did 406whp 371 trq uncorrected and 413whp 480trq corrected! My i have stock 99 heads with dual gold valve springs,TSP 231/237 cam, pacesetter lt, ory, magnaflow,l s6 intake, ported tb, asp pulley, NGK tr55 plugs, msd wires, ls7 clutch, think that it! and it still needs a tune
Old Mar 1, 2007 | 06:47 PM
ok stopped by SQR today and my numbers SAE 455/405
