NA 6.0l (370) Record???
Old Dec 25, 2006 | 01:47 PM
  #61
Benjamin Russick's Avatar
Do you have a better dyno graph, so we can see what's going on?
Old Dec 25, 2006 | 03:05 PM
  #62
KGSloan's Avatar
now this thread is funny
Old Dec 25, 2006 | 07:52 PM
  #63
smok'nZ's Avatar
MASS seller approved
true but no matter what he made 550+ and has a back up 502 hp 408(not as built as 370) so he is set
Old Dec 25, 2006 | 08:42 PM
  #64
Y2K Pewter SS's Avatar
4 pages of b/s and the original question has never been answered, what is the record for a n/a 370 cube LS1. I think Tyler(1bad00ws6) is wanting someone to post a record of say 450RWHP so he can wave a huge b/s flag in Scotts(car owner) face.
Funny thread though
Old Dec 25, 2006 | 08:58 PM
  #65
chino_man279's Avatar
I would guess someone has one in the 520 range with a 6 speed, 10 bolt, and 16" rims. This assumes pump gas, full belt, hydraulic roller, etc.... Vengeance has had some kickass cars lately that are head/cam 364" motors. High horse head/cam 346's are in the low 500 range. I would hope the extra 24 cubes would get about 1.7 more horse per cubic inch which would be about 40 horse at the motor.
Old Dec 26, 2006 | 01:05 AM
  #66
Harold Sutton's Avatar
Originally Posted by 1BAD02WS6
no need to be rude fuckstick. I will be the first to tell you i know nothing about autos or dynoing an auto, But i do know that everytime i have been to a dyno session where an auto car downshifts on the dyno it shows a HUGE tq spike and this never showed on this dyno.
i never said a M6 car will pull harder in 4th. I simply asked if the dyno would read lower in an auto if the pull was made in a lower gear (as it did in my M6 car). So by my logic your reading comprehension sucks. Wheather his car made this number or not does not matter. Wheather his car is a 370 or not does not matter. All that matters now is that i made a post asking what the highest recorded dyno was for a 370. I did not ask for some dick lick to tell me to think things through because he thinks he is the king of cars
A stick will record the highest horsepower if pulled in the 1-1 gear. An automatic will show unusually high torque readings when the person doing the pull floors it below the torque converter's stall speed. The converter then multiplies the torque until it passes that stall speed point. It is not possible for a T-400 to downshift if it has a manual valve body unless pulled into a different gear manually but they often sound like they have shifted down because of the converter's slippage and show monster torque readings till they pass the stall speed. I've never seen split readouts like the ones pictured, most Dynojets overlay torque and horsepower on the same graph. A Mustang Dyno is different than a Dynojet so usually reads from 20-40 horsepower lower numbers. There is no use trying to cross reference them as they won't read the same, ever. No way to say who is right or wrong, they're just different. The first pull my son's car made on a Dynojet with the old 481" motor it sounded like it exploded when the operator hit it at around 3500 RPM in high. It took a little over 3 seconds to go to 7200 RPM in high gear. The torque read 638 ft.lbs. and trailed off as the RPM climed. The final reading was 561 RWHP so the torque was quite a ways off because of converter multiplication down low.
Old Dec 26, 2006 | 02:26 AM
  #67
Flash99's Avatar
Originally Posted by Harold Sutton
A stick will record the highest horsepower if pulled in the 1-1 gear. An automatic will show unusually high torque readings when the person doing the pull below floors it below the torque converter's stall speed. The converter then multiplies the torque until it passes that stall speed point. It is not possible for a T-400 to downshift if it has a manual valve body unless pulled into a different gear manually but they often sound like they have shifted down because of the converter's slippage and show monster torque readings till they pass the stall speed. I've never seen split readouts like the ones pictured, most Dynojets overlay torque and horsepower on the same graph. A Mustang Dyno is different than a Dynojet so usually reads from 20-40 horsepower lower numbers. There is no use trying to cross reference them as they won't read the same, ever. No way to say who is right or wrong, they're just different. The first pull my son's car made on a Dynojet with the old 481" motor it sounded like it exploded when the operator hit it at around 3500 RPM in high. It took a little over 3 seconds to go to 7200 RPM in high gear. The torque read 638 ft.lbs. and trailed off as the RPM climed. The final reading was 561 RWHP so the torque was quite a ways off because of converter multiplication down low.
+1
My auto did the same thing, spiked up, and since HP is a measure of tq skewed the numbers up quite a bit while the tc stalled up.
Old Dec 26, 2006 | 08:40 AM
  #68
OUTLAWZ RACING's Avatar
Old Dec 26, 2006 | 10:48 AM
  #69
Mcduffys's Avatar
Bull
Old Dec 26, 2006 | 07:14 PM
  #70
linn.35's Avatar
1bad02ws6, you live in Tulsa and it been ~50 degrees there right?
There are ways to manipulation dyno numbers one of the biggest is smoothing which on your graph is set to max. This will take any spike out of the graph and make it as smooth as possible. If you were spraying a small shot this would be a good way to hide it.
These numbers are corrected, I personally have put a space heater next to the temperature sensor and closed the box in which it was contained. This obviously manipulated the numbers and there was an increase of 25 whp.
Can you please show us the unsmoothed and uncorrected graph?
Old Dec 26, 2006 | 07:24 PM
  #71
1BAD02WS6's Avatar
no i cant unless i go back to the dyno shop and since this isnt my car im not going too. It was about 56 degrees that day but i understand what your saying about tricking the dyno.
Old Dec 27, 2006 | 11:02 AM
  #72
10secclub's Avatar
im a very good friend of scotts (cunfuzed) and i know for a fact it wasnt sprayed because i help put the car together and yes the mph is low due to it being a turbo 400 car and the gearing
Old Dec 31, 2006 | 03:48 PM
  #73
M3 Muscle's Avatar
So is the owner ever going to post or are we ever going to get a good full dyno graph?
Old Dec 31, 2006 | 06:03 PM
  #74
cws T/A's Avatar
[QUOTE]and yes the mph is low due to it being a turbo 400 car and the gearing
112mph is what a bolton car pulls in the 1/4, a 550rwhp auto should run 130+mph. this dont make since , all that power with a 3speed auto, to much gearing is this a 1/8mile car? what gear is it running. looks like a streetdriver to me with the bling bling wheels .
A 5000stall/ 8.8 rearend 4.30 gears sounds like this , this car makes 430rwhp / 387rwtq with the converter locked up . Trex cam only ,4l60E 7000rpm stockshortblock 28/10.5/15's . Still pulls 120+mph in 3rd gear
http://smg.photobucket.com/albums/v4...t10secpass.flv
Old Dec 31, 2006 | 08:22 PM
  #75
1BAD02WS6's Avatar
5. Now as far im concerned this thread can be locked and deleted. here is a PM the owner sent me
LOL T I right now am battling some kind of sickness. I am not mentally preped for the nuke in which that one statement would cause. I ate crap for 3 months when I told everyone I was going to build a 370. Now I am enjoying the fruits of that labor. I dont want to end up getting involved in this 1st hand and it leaving sour grapes in my mouth. I am also not going to get provoked into telling how it was put together also. You rode in the car. You know what it feels like. The dyno may have been skewed (it was a ricer dyno after all) but I dont think 100hp. I did expect 500 at least though. The car is barely streetable. It is a race car as it sits right now. I will be pulling this cam out soon. VERY SOON!
no he will not post in this thread it needs to be and thrown away. I apologize for making the thread, i never knew people took dyno racing so seriously Maybe some time soon when he goes to Ed wright for a full tune he will post another vid and graph and more specs. He just couldnt beleive the hate that was coming to him from fellow enthusiast and didnt want to stir the pot any more.
Old Jan 1, 2007 | 12:20 AM
  #76
Gary Z's Avatar
Obviously not right. Other than near top end, the torque and power curves are essentially the same shape. This is physically and mathematically impossible. Where the torque curve is flat and non-zero, the power curve will be a straight upward slope. I'm not saying these curves are deliberate deception. Dynamometer power is calculated from measured torque. It could be that the dyno’s computer was bonkers and needed to be rebooted.
Old Jan 1, 2007 | 04:05 AM
  #77
VINCE's Avatar
Shorty Director
Per your request I will lock this thread. We were all hoping the owner of the vehicle would answer a few questions. Maybe in the future he will post..
