New dyno numbers
Old Jan 5, 2007 | 10:09 PM
dug's Avatar
dug
oops, I mean 70mph. nevermind
do you have a graph with rpms instead of mph?
Old Jan 5, 2007 | 10:23 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
They are using every ounce of the higher hp and tq is there at every shift.
That's just insane. The air sucked tonight also. The humidity was way up and the BP was down so there's a good bit more left in it.
Old Jan 5, 2007 | 11:14 PM
ls1 joe's Avatar
Dug,
Did I forget to mention that I am not racing a diesel. I guess Since it is not a torque turd, it won't go down the track either. Also the rpm pickup on the dyno was having a had time keeping up.
Old Jan 5, 2007 | 11:17 PM
dug's Avatar
dug
car is gonna fly. what times and mph you anticipating?
also, what made you go with 385 ci? whats the bore and stroke? or is it secret
Old Jan 5, 2007 | 11:21 PM
ls1 joe's Avatar
It went 9.61@143 hitting the revlimiter at the 1000ft mark. This was the 2nd pass on the new engine. The humidity got so bad at the track that we had to call it a night. The DA was terrible and the humidity was 90% with a BP 29.60
Old Jan 5, 2007 | 11:23 PM
gator's 99TA's Avatar
absolutely insane. did EK build this motor? whoever did it, did an outstanding job. how does 8K rpm feel? lol
Old Jan 5, 2007 | 11:26 PM
ls1 joe's Avatar
Actually Erik and LME both had something to do with this engine. As for the 385ci it was just some parts that I had acquired. This seemed to be the best combo for the parts that I had.
Old Jan 6, 2007 | 12:18 AM
BOTTLEFEDLS1Z's Avatar
Erik is the man!!!!
Old Jan 6, 2007 | 04:52 AM
allngn_c5's Avatar
Originally Posted by TXCAMSS
Here's the graph guys!
Wicked or what?
Very nice !!! That is some serious HP !!! Tq holds on very well up top, doesn't drop off like everyone elses does around 5000-5500. Those heads and intake with a 106 mm TB really work well together. Curious about the airflow of the heads?? Must be sick, because we all know that you need air flow to keep a good Tq number up top (8000 rpms in your case). Great job and thanks for posting the Graph for us to drool over......This may be a dumb question, but can you drive her on the street, or track only ??
Old Jan 6, 2007 | 05:11 AM
LS1Fever99's Avatar
Wow, that is one healthy *** small block! Those are some sick *** numbers and holy ****** compression batman!
I didnt notice but are you on a built auto tranny? If so, what stall converter do you have and what gears? I might have missed it, but just in case.
EDIT: Just noticed your sig and it looks like you are have an M6. Insane! What clutch/flywheel combo are you using?
Old Jan 6, 2007 | 02:46 PM
Louie83's Avatar
I have yet to see a 402-427 range engine make that much power.
Dayyum!!
Old Jan 7, 2007 | 02:39 AM
  #32
Bryan@LME's Avatar
LS1TECH Sponsor
Nice results Joe. Glad to see that shortblock working well for ya.
Old Jan 10, 2007 | 11:38 AM
  #33
getusum's Avatar
Gotta give it to the guys @ LME....Great experience to work with...Congrats to Joe and the gang @ T56...can't wait to get my tranny done....
Old Jan 11, 2007 | 11:51 AM
  #34
ONEBADWS6's Avatar
Is this a dry sump setup?
Old Jan 11, 2007 | 01:21 PM
  #35
ls1 joe's Avatar
No it is the stock wet sump.
Thanks,
Amber
Old Jan 11, 2007 | 02:18 PM
  #36
ONEBADWS6's Avatar
8k plus on the stock pump!!!!! I thought I was nuts for going to 7500rpm.
Old Jan 11, 2007 | 03:45 PM
  #37
ls1 joe's Avatar
We have been turning our car 8000rpm's for more than 3 years now. We did it on the stock short block, stock heads and will continue to do it with this setup. We have the ability to set the rev limiter as high as 12,000rpms but that shouldn't be needed. We have proven alot of things can be done with the right combination.
Thanks,
Amber
T56Rebuilds.com
Old Jan 11, 2007 | 03:49 PM
  #38
allngn_c5's Avatar
Thanks,
Amber
T56Rebuilds.com
Holy **** Joe !!!! I must be the ultra conservative shifting at 6600 or so.
Old Jan 11, 2007 | 09:42 PM
  #39
ls1 joe's Avatar
It is not quite stock oiling system. I have a Moroso pan with the pick up in the very rear of the pan P/N 21150 I think. And with that pan, it relocates the oil filter to a remote housing. I have a CV products oil filter housing and a very large NASCAR style oil filter, I also have a Melling pump with the red spring. The total volume of oil for my system is 9.5 Quarts. Yea, thats right 9.5 quarts.
Old Jan 12, 2007 | 10:36 AM
  #40
ThunderStruk's Avatar
Dayyum!!
Actually there have been a couple that have done that with those size motors. One imparticular example would be here :
https://ls1tech.com/forums/showthrea...hlight=fms+427
If you backfigure 850fwhp with a good 15% loss that still comes out 725 at the tires, and i highly doubt through that drivetrain it is even a 15% loss.
None the less good numbers Joe and congrats for a nice setup!!!!
John
