Gen I conversion untuned dyno results... Disapointed...
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
I dynod it last night on a land & sea dyno which reads almost exactly like a mustang dyno give or take 5hp. I put down untuned in 100% humidity, 322rwhp @ 5729rpm and 309rwtq @ 3556rpm with a 9.5 air/fuel. So theres probably around 40 more hp after a good tune. They said that would be close to 400rwhp on a dynojet dyno. In comparison, they had a cammed, exhaust, boltons, ls1 with a 150shot that runs low 11's, high 10's put down 420rwhp. And a Dodge Magnum rated at 425hp from factory put down 320rwhp. So considering that my numbers aren't all that bad. After I get it tuned I'll let ya'll know what it does and then I'll post another graph. What do you all think?
Specs:
355 C.I. LT1 to Gen I Conv.
Hyd. 561/573 lift, 230/236 Cam, 1.65 Roller Rockers, Patriot 195cc Port/polished Alum heads, 58mm TB, Weisco Forged Flat top Pistons, Balanced/blue printed, HOOKER Long tubes and 3" Catback, 4.56s, 36# inj, e-waterpump, LTCC ign, Victor Jr intake, all boltons...
Specs:
Originally Posted by Ls1Bait
Yea the A/F if off, with some tunning you will feel the power.
why did you pull the LT1? Any pics of the new setup?
