Auto/MS3/PRC 5.3 2.5 Dyno
Old Jan 15, 2007 | 07:29 PM
MRZ28's Avatar
Default Auto/MS3/PRC 5.3 2.5 Dyno
well i finally got the car dynoed..380/340 unlocked/corrected.. i dont know what to think about these numbers. let me know what you think. Mods in sig.
Old Jan 15, 2007 | 08:04 PM
bad6as's Avatar
im sure they will be higher with the converter locked
what are 308s
was the cut out open
Old Jan 15, 2007 | 08:11 PM
MRZ28's Avatar
308s are the stock gearing out of a V6 F-body. Yes the cut out was open. I have seen some Auto MS3 cam only cars dyno higher than that. this was also after i based lined 355 rwhp, so my tuner was able to pull another 25 hp out of it.
Old Jan 15, 2007 | 09:05 PM
waterbug1999's Avatar
You got the Dyno sheet?
Old Jan 15, 2007 | 09:29 PM
00 Freak's Avatar
Thats good numbers I think for being unlocked. I wasn't too happy when I left the dyno when I saw my #(359whp 336wtq unlocked) but when I went to the track it was a different story. Your car should be a monster at the track though. I've heard generally you loose 20-30hp when the converter doesn't lock up. Good job. Dyno # don't mean nothing. Wait till you get to the track.
Old Jan 15, 2007 | 09:36 PM
I thought that the numbers usually go higher when unlocked due to the verter flashing... Whch would cause your dyno numbers to be higher then unlocked like it should be...
Old Jan 15, 2007 | 09:39 PM
00 Freak's Avatar
Hopefully we can get someone to chime in and set this record straight.
Old Jan 15, 2007 | 10:08 PM
MRZ28's Avatar
Hey 00Freak what are your mods and times if you dont mind me asking
Old Jan 15, 2007 | 10:15 PM
bjamick's Avatar
Ya auto cars can pick up like 30-50hp with the converter being locked. Maybe even more. Nice numbers, if you would have locked the verter i think you would have seen 450 IMO.
Old Jan 15, 2007 | 10:19 PM
MRZ28's Avatar
Wow, I havent heard that, Next time Ill have to lock the verter.. im aiming for 400 whp with the verter unlocked so, im hoping with a TB and True duals ill be there.
Old Jan 15, 2007 | 10:33 PM
HartAttack's Avatar
00 Freak went 7.3x in the 1/8 with like 93.x mph
basically a 11.46 1/4 time at 118-119 mph
Old Jan 15, 2007 | 10:39 PM
I guess he has more then a lid.. lol
Old Jan 16, 2007 | 05:19 AM
bad95killer's Avatar
If i got 380rwhp unlocked i'd be more than happy buddy so 400rwhp thru unlocked verter will be way too impressive
Good luck .
peace
Old Jan 16, 2007 | 05:44 PM
MRZ28's Avatar
Thanks for the Input...Ill be running it this weekend at the track, ill let you know how it runs.
Old Jan 16, 2007 | 06:21 PM
00 Freak's Avatar
I have TR224, asp pulley, ported&milled 241 heads, jet-hot headers, TSP rumbler, ls6 intake, 3.73, yank4k stall. I've ran 7.34@93mph. I've added the x-pipe and soon I'll have qa1s so hopefully better times. I did have cats before I installed the TD's. This is on my formula not the camaro.
Old Jan 16, 2007 | 06:43 PM
MRZ28's Avatar
Wow, what whas your race weight at?.. is your car gutted?
Old Jan 16, 2007 | 06:58 PM
JNorris's Avatar
Moderator
Nice numbers. Please post up your track times.
John
Old Jan 16, 2007 | 07:11 PM
00 Freak's Avatar
Last time I weighed it was 3480 w/o me. But I'm going to check it again soon. Goal this year is 7.0s in the 1/8mi or 10.9s in the 1/4 with this cam.
Old Jan 17, 2007 | 01:30 PM
SSilverSSurfer's Avatar
i went 11.76 116 with a 3800 stall and an S cam(pretty much the same thing as an MS3) and dynoed 382hp on a mustang.
Old Jan 17, 2007 | 02:16 PM
1fast01's Avatar
Hey MrZ28; Dan told me about your car...I expected more outa my combo but the verter was also unlocked. On the same dyno I pulled 429/420 this past Friday
