Another dyno estimate thread =)
Old Jan 18, 2007 | 12:34 AM
Lurius's Avatar
Default Another dyno estimate thread =)
I'm building a 408 for my truck, it should be finished and installed in February. The
Parts going in:
Gm iron block, 4.030 bore
ARP main studs, ARP head bolts, ARP misc bolts
ls7 lifters(the 100$ ones from SDPC)
Eagle H beam rods
Mahle Pistons, -12cc dish
Cometic head gaskets
317 cast heads hand ported
Dual springs(PRC)
ms3 cam(I know, a baby cam)
4" stroke Eagle forged crank
Clevitte bearings
Stock truck intake manifold
8.1L truck injectors
Think that covers the engine parts
Bolt ons:
Pacesetter LT headers
No cats
E-cutout
S&B air intake
misc, standard bolt ons
With that said, the truck is an 04 silverado, 2wd, 4l60E(upgrading before motor going in), 3500RPM stall, 3.42 gears.
The compression ratio should be 10.25:1
Any estimates on the 1/4mi(truck weighs 5000lb) would be nice too, but more interested in dyno#'s for now. I'll find the 1/4 times this spring after the motors broken in and I get my new gears installed.
Thanks a bunch guys.. I'm anxious to actually get this thing finished and put on the track and dyno.
Thanks!
Lurius
Old Jan 18, 2007 | 01:46 AM
stone4779's Avatar
450ish rwhp 490 rwtq
Old Jan 18, 2007 | 12:23 PM
Lurius's Avatar
That would indeed make me happy!
-Lurius
Old Jan 19, 2007 | 02:26 PM
stone4779's Avatar
-Lurius
Some guys are breaking 500rwhp with the FAST intake/TB & good heads
The reason I put 450rwhp & 490 rwtq is I'm guessing the truck intake is going to make a little more torque and a little less HP...
Old Jan 20, 2007 | 08:49 PM
Lurius's Avatar
Well, its all good. I need more torque to get me moving. Weighs 5000 lbs without back seat or spare.
-Lurius
Old Jan 21, 2007 | 12:50 PM
Irocss85's Avatar
Im gonna agree with this due also to the cam being soo "small" for your engine. it should be a pretty docile cam that builds GREAT torque in my opinion. similar to a 224/228 in a 346ci engine. should fit your build perfectly. however Id put in bigger gears to get that big *** truck moving better.
Old Jan 21, 2007 | 05:55 PM
stone4779's Avatar
-Lurius
exactly
Old Jan 22, 2007 | 09:14 AM
Lurius's Avatar
Im putting 3.90's in this spring before the truck sees the track.
-Lurius
Old Jan 22, 2007 | 01:48 PM
stone4779's Avatar
I hope you have some good tires to stick that power to the ground because my bolton '01 RC 5.3L w/ 3.73s would rip tires to pieces....lol no weight on the rear tire....
Old Jan 23, 2007 | 03:25 PM
Lurius's Avatar
Lol, I have 20's now, so I may be having to save my old 16's for burnouts lol, those 20" tires are expensive! But they do get good traction.
-Lurius
Old Jan 26, 2007 | 06:20 AM
joelvette's Avatar
i will be very interested in these results as im building the same motor with a fast 90, n.w.90, and not sure which cam. all for my 3200lb 73 firebird. just need cam help. thanx joel
