what could be the problem with locking a stall on a dyno run?
now I have a 700r4 in my 95 (its out of a 3rd gen) and I have a manual lockup switch and plan on testing with it on and off. I use it on the freeway (seems to be good for about 250-300rpm on my 3800 stall) and at the track, but I need a shift kit cause I dont think it locks under WOT with out the shift kit.
I know the GN guys have been doin this forever and gain alot of MPH from it at the track. so why dont 4L60E guys run a lockup switch for track times?
I do. I pick up 2 extra MPH out the end when locking my converter. You have to be somewhat scientific about it though and not just lock it up when you feel like it during a run. Go to a dyno and get a dyno pull locked and then unlocked. There will be an exact MPH where the curves cross. That's where you lock the converter up for the maximum gain from doing this. Try it.
BTW on my stock longblock bolt-on motor this point was 84.4 MPH with 3.90 gears and PT4000 converter. I've yet to find out where this point is with my new head/cam combo but you can count on me getting this information.
so can anyone point to anything neg. about locking on the dyno?
Frost, just read your thread about your car build. I must say VERY SWEET. Im sure you are enjoying that car with your setup. what kind of track times you seeing now, and whats the boost up to? and what the hell happened to your oil pump oring? was it cut from someone jamming the pipe into the pump? cant figure out how that happened while assembleing the eng. on a stand. anyways cool story and thanks for all the pics and story.
chris
chris
...there wasn't an o-ring problem, either a new comp OE lifter failed and wiped a lobe, leading to eating a bearing, or the bearing went and the trash stopped a roller on the lifter. Either way, same outcome. I am running 15.5psi with methanol on the HPE shortblock with TEA heads and it feels NICE
I've been at this level for about 900ish miles. I don't know how quick it is yet, it hasn't been on the track, but I was dead even with a new C6 Z06 for 3 pulls from second gear to the top of fourth when I was at about 9psi, and it's a whole different animal at 15psi
The turbo brings the luxury of a tall rear end gear, so the M6 is coming out for the th400 and a 3.08 gear with a hefty but tight stall. I hope to be on the track by May with it. Thanks for the intrest
As far as locking the converter during a race, using the fact that it's he who can average the most HP in each gear will be quicker all else equal, find at what RPM your engine HP peaks, then lock the converter so that your RPM drops and crosses that point again, like another gear. Another way to look at it, if we had an infinate ratio transmission and a joy stick to control it, we would hold the RPM at the peak HP RPM point throughout the entire race, this is what we are crudely trying to accomplish with the TCC lock up.
Try this, it works.
when I get my dynotune done, I'll have to have him plot it diff. so I'll be able to see at what mph that happens. and give it a back to back test at the track doin it that way, vs the way Ive always done it. which is turn the sw. on at the starting line after Im staged and back in first gear.
man I cant wait to hit the track again.
I'm using what started out as as Rock-On Stage 5 4L60e. It's been totally gone through again and the full manual option was chosen. Mine can be switched back to automatic shifting by going back into the valve body and changing a couple of things. Automatic gurus please chime in as I'm sure you can explain what I'm talking about.
Don't look for great ET gains from doing this. You're only using the extra horsepower available for 4 seconds or so of a track pass. I'd expect .05-.1 gain at the most but your trap speed will go up.
I see. basically full manual option in your shift kit.
far as track times, in my case, with my old iroc, I picked up .15 and 2 mph consistantly. that was with a faily tight conv. though. full size, 2800rpm stall speed on a mid 12 sec. car. seems there would be more to gain with a higher stall speed, and a car that makes more torque.
interesting though edcmat-l1.
keep them comeing. anyone else?
chris
