NOVA Dyno numbers today
Old Jan 27, 2007 | 03:57 PM
Phil'sC5vette's Avatar
Default NOVA Dyno numbers today
I had my car dyno's this morning
I did 425 RWHP and 400 RWTQ through 3.90s.
Old Jan 27, 2007 | 07:01 PM
bad95killer's Avatar
Not bad with 228R buddy
How much were the heads milled ?!
peace
Old Jan 27, 2007 | 08:14 PM
I milled the heads off -.020 and used the GM gaskets. Im at about 10.85:1 compression.
My AFR was crazy under load. It dropped to 10 ish and go up to about 10.75. So I know there is room for improvement. I uploaded another tune, and the AFR was 14.50 then dropped to about 10.00 and also leveled out at 10.75.
My goal was 420 RWHP when I had stock 3.43 rear. 425 RWHP through 3.90s was a pleasent surprise.
Old Jan 27, 2007 | 08:28 PM
It seems your A/F ration is way too lean then way too Rich buddy ?!
peace
Old Jan 28, 2007 | 04:47 AM
yes, I need to figure that out. Even when I uploaded a real fat tune, the AFR went to 14.5, then dropped to 10.5 and settled in at 10.75
Old Jan 28, 2007 | 11:39 AM
Here's a couple links to my dyno runs. One is the dyno numbers and the other is the Air Fuel ratio. The AFR was a tail pipe reads
http://www.corrundum.net/photos/phil_afr.jpg
http://www.corrundum.net/photos/phil_dyno.jpg
Old Jan 28, 2007 | 07:49 PM
The red and blue lines are the first tune, and it drops down to 10.00 AFR as soon as there is load.
The green and black lines are another tune I up loaded for SD, and it went real rich and dropped to 10.75
Looks like the car has more work on the tuning side.
Old Jan 29, 2007 | 08:02 PM
Any suggests on how to fix the tune
Old Jan 31, 2007 | 05:00 PM
Xtnct00WS6's Avatar
Where did you have it dyno'd?
Old Jan 31, 2007 | 10:42 PM
Classic motorsports in manassas
Old Feb 1, 2007 | 07:00 AM
SideStep's Avatar
Is that a Dyno-Jet???
Old Feb 1, 2007 | 07:38 AM
edcmat-l1's Avatar
It was a dyno dynamics but the #s were dead nuts with my DJ248. Had a customer dyno there and made within 1 HP as on my DJ. Another customer stated his #s were almost identical as another DJ.
Phil, if you're just trying to level out the A/F at WOT just use the PE table. bring it up in HPT and look at your graph and add or subtract in the areas that require either.
Old Feb 1, 2007 | 08:02 AM
Sigforty's Avatar
Not some bad numbers there! Especially the 400 torque.
Old Feb 1, 2007 | 02:36 PM
The numbers are good, but when the tune gets right, the car will run much better
