Dyno tyning tomorrow
TSP Torquer V2 232/234 .595/.598 @ 113 lsa
5.3L Stage 2.5 heads by TSP 317cfm at .600 lift
3400 stall. 2.1 str
Ported TB
Pacesetter Long tubes
SLP Lid
True Duals with magnaflow mufflers
any guesses?? i dynoed 337 whp before and im hoping for 410 after tuning.
lets have a contest!
so i had no internet
i dynoed at 401 and 370 ft lbs of torque
first run i did 371 and then after tuning i got up to 401, also had a torque spike of 818!!!!!!!!!!!!! wooooo
and thats not corrected unless the computer auto corrects?
also this is on an ls1 intake
i need an ls6 manifold plus bigger TB and underdrive pulley ha, then ill be flying and be done with the damn car
damn i need boost too
Nice numbers man, get that ls6 intake and you'll see 415ish rwhp.
Good numbers though for a crappy intake, stock TB, and stock pulley.
Yea, he'll pick up quite a bit of power under the curve after 4-4500 and about 10-15 peak with the ls6 intake.
3400 stall. 2.1 str
Ported TB
SLP Lid
i kno ur an A4 w/ a stall so it will rob u of somepower, and u also got TD setup. but for comperision heres mine, numbers in the sig
i dynoed on a 12 bolt and 3.73s, and on my heavy chrome Z06's, i dont got a pulley, and my TB is stock(unported), my cut out was open, its an 02 so i got the LS6 manifold, my heads are un milled, and i opted for the 2.04/1.57 valves, i got the 243 castings
did u mill ur heads??? whats the diff between 5.3 and ls6 heads??
do u have any idle clips??? or any rev clips or races?
