AFR 205's (347 CID) 510 RWHP / 442RWTQ
Originally Posted by tmoneyr007
The speculation on these numbers will be put to rest at the track hopefully in the next month or so....the MPH the car runs will back the dyno figures. I dont even care about the ET because trap speed is where its at when discussing (questioning) power output. ET shows how well the car applies that power, track prep, and driving technique primarily related to 60 foot times.
Tony
1 Post
Originally Posted by Tony Mamo @ AFR
Thanks guys....
Concerning the DCR I dont know exactly what it was and of course it will vary depending on who's program you use to run it on (it really is a theoretical tool that I feel people on the Internet have begun to place to high on emphasis on versus's real world proven results and experience), BUT....if I had to guess I bet it would only be in the low 8's. Hell, the DCR on my own 383 is only in the high 7's yet that engine just popped 497 RWTQ and 543 RWHP with a larger header and some addtional time spent tuning on the chassis dyno. While more static CR would have helped both (the DCR and power output) my point is the engine still makes huge power in spite of a DCR most would agree is on the low side. I think to date it is still the strongest pump gas 383 I have seen but could be wrong.
Regards,
Tony
Regards,
Tony
I was just curious about the DCR in relation to how pump gas friendly this might be with a slightly lower SCR. You guys have got some great results. I am looking forward to my new combo coming this summer (does the madness ever stop?). I am going to be taking a tuning class so I can know a little something about tuning, but I will not be doing my own tuning...it is just a gee whiz like to know thing. John02Ss is my tuner.
Jon
Tony,
It was great meeting Saturday and I am astonished at the results I was able to put down for Dennis and you. Oh, and I will get you the scanned image of the actual dyno sheet soon. Let Dennis know my neck is doing better today. I will try and make time to help you with your car as well very soon.
As for the pther post, yes it is the same dyno, and if we can keep it seperate, it would be great.
Originally Posted by 12secSS
Tony,
This one needs to go on our featured vehicle link.
Hey Tony, I think you were the one I met at SEMA. I have not forgotten what we talked about, so email me.
-Ken
HP Tuners
Originally Posted by ChucksZ06
Is the cam a solid? What valve springs? Thanks. I wish I had that engine in my car.
Originally Posted by Amerkin
Haha! Sorry George, I was going to recommend a good physical therapist for you if it continued to bother you! Things tend to happen quickly with that m12/3.90 gear set. I was out in the car yesterday and what a hoot it is to drive, with very docile manners, until you ask it for more. Docile quickly becomes explosive. Quite fun except for the occasional neck ache! Thanks again George for a job very well done.
Originally Posted by jeffstar
Nice numbers..... what did these heads cost to make this power?
I've been searching for that information for a while now.
In Dennis's case they were obviously damaged used heads so he spent some additional money on valves and a few guides that were broke....we then freshened the valve job, cleaned the heads, and milled them to 58 cc's. The only thing you would have to do ordering them new is to provide us with the correct mill info (58 cc's in this case obviously) and also opt for the 8019 spring upgrade (about $100).....Total cost would be $2565 direct from AFR including the mill and spring upgrade.
The key is getting the rest of the combination to match.....thats where all the money comes in. Make no mistake about the fact that Dennis's entire combination takes $$$ to duplicate, but the end results justify the price of admission.
BTW the cam was a custom ground hydraulic roller....not a solid
Hope this helps...
Tony
#32
Kleeborp the Moderator™
So Tony...
1. How many times did you remove the intake manifold during testing?
2. How many times did you remove the valve covers to adjust the rockers?
3. Why were there no CNC marks in any of the runners?
4. Why can I not produce these same results in my home-ported, GM-cast LS1 heads (which, by the way, are much more affordable)?
5. Can this setup run on 85 octane?
For the others out there, yes, I'm joking...Tony will certainly get it. Great results. Not bad for some "outdated" heads...
#33
LS1 Tech Administrator
I'm still floored that you made these numbers with cats! Go California, LOL~!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
#34
Originally Posted by MeentSS02
So Tony...
Be wery wery quiet.....(my best Elmer Fudd impersonation)....you might wake up Flow-Troll
#35
#38
What have you been searching for? All this info is readily available on our website or a quick PM away by contacting myself.
Hope this helps...
Tony
Hope this helps...
Tony
#39
Tony,
One thing I have noticed as of late is that you seem to have an affinity towards the new, lighter weight Yella Terra rockers...do you consider those to be a good (albeit cheaper) alternative to a more expensive shaft mount setup (like Jessels)? Seems like they are doing their jobs, and quite well. I would also assume that they don't require any additional machining?
