Vengeance Racing 402 Iron Block/TFS Heads RESULTS INSIDE
Old 02-28-2007, 01:41 PM
gnx7's Avatar
What compression is this motor? Was this on 93 octane I assume?
Is this cam size in the 250*+ duration or bigger/smaller?
Nice numbers especially for a 402.
Old 02-28-2007, 02:05 PM
ATVracr's Avatar
Originally Posted by Brian Tooley
I've seen Mustang dyno's that were as high or higher than dynojet's and I've seen Mustang dyno's that were very low. I would guess your power on a dynojet with a 10 bolt or Vette rearend to be 520-550 RWHP with your 130 MPH trap speed. What is your compression and how much does your car weigh? You said it was a solid roller right?
What's going on with the TFS heads that PSI bought? Head comparo?
PSI's dyno hurts alot of peoples feelings
Compression 11.3 .... Hyd roller ,still on stock rockers , 3,678lbs on a set of brand new scales.
I was over there yesturday and have not seen them yet.
We were thinking about doing a comparison but its not worth 10 hp either way for me to find out on my N20 car.
We have done some good back to back stuff on my car with AFR 225's and ET 225's, both sets of heads tested on 2 different cams. Dont think I want to put in the work to do a test for the TFS's for the fun of it. Jeff said he wasnt going to get a SUPER deal on the heads so I was like well I aint trying them then
Do you think they would be worth anything over my current ET 225's?
Old 02-28-2007, 02:06 PM
pdd
pdd's Avatar
another nice combo from you guys,
Old 02-28-2007, 02:53 PM
Super Hulk Smash
JakeFusion's Avatar
What are the approx specs on the cam? Is it a 240/244 like the Vindicator?
Old 02-28-2007, 03:09 PM
Brian Tooley Racing's Avatar
For some reason I thought you still had the AFR's on the car. Since I have not seen the TFS/ET 225's tested back to back then I can't say either way, but I would think the 10 HP you mentioned would be the max, but who knows.
Old 02-28-2007, 03:37 PM
LS1 Tech Administrator
Patrick G's Avatar
This thread again reinforces how strong the cathedral port heads STILL are for larger motors. In fact, I've been very underwhelmed by the dyno numbers from the L-92 heads up to this point. Sure they make nice flow bench numbers, but they don't make anywhere near the power that we've seen from the top performing cathedral port heads like these TFS 225s.
Bottom line, don't be too hasty to write off the old style heads for making big power on a 4.0" bore. It may not be until you start running bore sizes of 4.10" or larger that the big-valved L-92s really start showing their potential.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old 02-28-2007, 04:03 PM
Yeah, or start turning the engine well into the 7500-8000 RPM range. We have SBF heads with over 2.20 diameter valves and over 400cfm, but they are on 440" engines with .850"-1.000" lift, and that's where they seem to like to live.
The thing that I learned a while back is to make a head that is "easy" to cam, and you will have a more popular head. Heads with lots of low lift (.100"-.200") or big valves are not easy to cam. That is not something a computer program taught me, it is what working with the stuff has taught me.
Also when you have one head flowing well with a 2.16" intake valve and 260cc port volume, compared to another head that flows as well or better with a 2.055" valve and a 225cc port, it pretty much becomes a no brainer.
The only time the bigger head will make more power is when the engine NEEDS the extra port volume, like with a bigger engine turning LOTS of RPM or with a BIG shot of nitrous, but the L92 head deck DOES NOT like a big shot of nitrous.
Old 03-01-2007, 04:38 PM
Hey Ron, give us the scoop, what was the approximate cam duration, inquiring minds want to know
Old 03-01-2007, 05:03 PM
slow trap's Avatar
i would like to know also.
Old 03-01-2007, 06:31 PM
HUNTER02SS's Avatar
Those are great #'s.I bet it will haul on the spray!!! Good job guy's.
Old 03-01-2007, 07:31 PM
URBHIND's Avatar
That's Promising #'s Considering I'm Looking At That Set Up
Old 03-02-2007, 12:07 AM
  #32
JRracing's Avatar
Sounds like a beast! I can't wait to see the n2o #'s.
Old 03-02-2007, 07:31 AM
  #33
LS1TECH Sponsor
Vengeance Racing's Avatar
Come on Brian you have to keep a few things to yourself. BTW it is not the cam it is the heads
Old 03-03-2007, 01:17 AM
  #34
santiago's Avatar
how do i get my engine builder to put this cam in my shortblock....will you tell him the specs???
Old 03-03-2007, 04:59 AM
  #35
beardWS6's Avatar
Nice numbers fellas!
Old 03-03-2007, 11:21 AM
  #36
slimcracka's Avatar
nice #s i cant wait to see this car run...and i herd the cam was 25x/25x, .6xx/.6xx, 113+2 cam
Old 03-04-2007, 12:50 AM
  #37
rmitchell242's Avatar
xx5/xx9 xxx-xx5 1xx
Old 03-04-2007, 09:12 PM
  #38
Chicago Crew UnderBoss's Avatar
Fantastic job and congrats you guys are on a roll and when will you have some numbers on a 11:25 to 1 compression 408 iron block, full n/a application, with the timing cranke up, etc, to see how close to 600rwhp you can get on pump gas on the venerable 408 motor with these TRICK FLOW heads which clearly are the best performing LS series heads that $ can buy!
Old 03-04-2007, 10:06 PM
  #39
SunshinePerformance's Avatar
So thats two iron 402's with TFS heads that are doing the unbelievable....How about that!
Attached Thumbnails Vengeance Racing 402 Iron Block/TFS Heads RESULTS INSIDE-tfs_225_heads.jpg
Old 03-05-2007, 09:16 PM
  #40
OUTLAWZ RACING's Avatar
Quick Reply: Vengeance Racing 402 Iron Block/TFS Heads RESULTS INSIDE
