Trex cam results
Old Mar 1, 2007 | 09:57 PM
bwil6488's Avatar
Default Trex cam results
All you guys running the trex post up some results. I installed one along with some Patriot Ls6 stage 2s. I have all the bolt ons (full exhaust, pulley, FAST 90/90). My results are 435 rwhp/405rwtq. I thought they were low. Need some comparisons. Car is a C5 LS1.
Old Mar 1, 2007 | 10:39 PM
moeZ28's Avatar
My numbers are in my sig. Those were pre- Fast 90/90, aluminum flywheel, and with only one cutout....now I have 2. I am goin back to the dyno with the new addons on the 11th.
Old Mar 2, 2007 | 11:33 AM
bwil6488's Avatar
Those are good numbers. Let me know as soon as you dyno. Where can I get some good cutouts? Do my numbers seem low?
Old Mar 2, 2007 | 11:38 AM
LostCauseZ06's Avatar
your numbers are a little low... my buddy put down 440 with the same heads, he was on a nitrous tune and had quite a bit of timing pulled though.
Old Mar 2, 2007 | 05:04 PM
chris93266's Avatar
6spd or auto?
Old Mar 4, 2007 | 04:20 PM
bursty's Avatar
What kind of numbers should the trex pull on the stock heads?
Old Mar 4, 2007 | 06:19 PM
30th t/a's Avatar
I say those are definately low. I would think that setup would be in the 460rwhp atleast. Cam only, stock heads & LS6 intake I think 420rwhp would be about right, although someone made 450rwhp, CAM ONLY but that was with TONS of tuning & tweaking and it was a shop car.
Old Mar 5, 2007 | 11:54 AM
bwil6488's Avatar
a 6 spd car with 4.10s. I thought numbers were low. Some said that they were respectable. Others say I should have more rwhp.
Old Mar 5, 2007 | 12:10 PM
98_Formula's Avatar
i wouldn't worry so much about the dyno numbers being a bit low, there's not a huge discrepancy (sp) that would make you tHink thEre is a problem with the setup.. just get to the track and see how it performs. dyno numbers aside, that cam usually performs quite well
Old Mar 5, 2007 | 12:30 PM
chris93266's Avatar
are you sure the tune is good? i'd guess about 450, but as 98_formula said, that isn't a large discrepancy.
Old Mar 5, 2007 | 12:35 PM
NoGamesLS1's Avatar
Thats seems to be shitty low numbers...what type of dyno?
Old Mar 5, 2007 | 04:59 PM
bwil6488's Avatar
Tuned on a dynojet here in Atlanta.
Old Mar 5, 2007 | 06:06 PM
1BadZ95's Avatar
For a Dynojet that is kinda low. Hell if you would have brought it to my local dyno you would be around the 380 range. lol (land & sea dyno)
