ETP 225 small bore results. Need opinions.
#41
Originally Posted by ls1408cp
ha fix it then, you kept the temps down did you have backwoods billy running a hose on the motor?
#46
1 Post
Looks like you have been through a lot with this whole ordeal. At any rate I am very sorry to hear that you finally get it done and your numbers aren't where they should be, then to add insult to injury now you are suffering from overheating issues. Sounds like you are in the same boat as me, if it weren't for bad luck you'd have no luck at all.
The guys at LG Motorsports are true leaders in the industry when it comes to standing behind there work, and customer service is unparalled. Bobby and Louis really hooked me up. The extra mile that everyone went to get my car right was great. Thats why I will definately stick with them for all my future performance needs.
Maybe you should consider a road trip to LG Motorsports and set up an appointment with them. Get your car checked over and hooked up correctly. Hell I have been there 3 times. Drove 15 hours from Michigan. No regrets at all. Loved the road trip and really got to see a good bit of the country. Trust me, if and when you get there you get treated like family. Get the car there by 8 am, they can start it at 9 am and problably have a solution in no time. They'll present the options and you decide what you want done. Go rent a car and check out Wiley, TX and the surrounding area. Lots of good restaurants. Nice place to stay for a few days, and when your car is done turn in your rental and go feel the difference that LG Motorsports made in your car. Good luck.
#47
I was hoping this thread would just die. Both sides spoke their piece.
Chris, please lay off Redline. I'm sorry if you had a bad experience with them but they really have treated me professionally. My overheating problems were present long before I ever took my car to them. They at least got the temps from 250 to 220. The stock radiator was obviously clogged and when they had it boiled out it definitely cured "part" of my overheating problem. Please feel free to post in my overheating thread in the Internal Engine section.
At this point I'm not going to keep shelling out money to have someone else try to fix my overheating issue. I'm able but usually not willing and I don't always have the time to do it myself so that is why I often use local shops. I still do a lot of the work on my car myself and this is a situation where it would be best if I personally figure out the overheating problem. I have another thread going because I am looking for ideas but it seems I am ultimately going to have to remove the heads and have them pressure tested. My overheating problems began on my stock motor after the heads were installed and they are still prevalent on my new motor which is using the same heads. It could be coincidence but I have tested nearly every inch of my cooling system and I'm still overheating. So what else is there to check?
If you have a comment about the overheating issue, please post it in this thread:
https://ls1tech.com/forums/generation-iii-internal-engine/786044-still-overheating-i-fn-give-up.html
