Bolt on M6 results
Is it true that Mustang dyno's are about 5-7% lower than dynojet's? I'm no bench racer, but that would mean around 366-370 on a dynojet, that seems a little fishy for a bolt on car. Maybe the mustang dyno was feeling generous that day
The car trapped 107 before the LT's, ORY and tune. I'll find out shortly what it traps now
I can't tell on the graph, but I do see that you made both 3rd and 4th gear pulls. Did you get the numbers you posted in 3rd or 4th gear? Just curious.
I think I that's what he meant anyways.
I figured that was only possible with a small cam.
same set up on an 01 m6 z28 all bolt ons no tune. I did around the same. Yes I did see around 370 on a dyno jet. I will find my dyno sheets and post them again!
I trapped 114 with all bolt ons!
I had near the same mods + ASP but - PP throtle body on a dynojet and had 345 & 360tq. Nice #'s
For comparison to ravensfan car for example, grannys car with the same mods but stock catback made 349/370 on a dynojet. BW Id guess yours would make a little over 36change/375 or so on a dynojet, but we dont dyno race too much round here
That hp is capable of trapping 112 on accident, 113-4 on a decent pass or better at full weight, little bit better than what grannys car did Good driving, good air thats capable of 115-116 and change mph at your weightBTW we did the first couple pulls to get the car in the ballpark in 3rd, not sure if you guys are aware of the load a Mustang can put on a car, but we have had people overheat cars on a pull or two because they are leaning on them too hard. We here "well weve made a bunch of pulls on a dynojet and it never gets EGTs like THAT".... well thats because theres no load
Low geared cars can take something like 7-10 seconds sometimes to make a full pull in 4th on our dyno. His car was wayyy lean to start with so we got that in the ballpark, then kept it in third so the gains could be seen from first pull to the final tune (thats the bottom two curves) Then we did a final pull or two to make sure the hella load doenst make it knock any in high gear where the timing was. if its cal'd right and used right these dynoes make for awesome tuning tools (weve pulled 3600-3700 lb cars off the dyno and ran new bests on the first full pass a bunch of times, anything from 11 second cars to 8.90 cars) Used wrong and they are worth less than even a dynojet Nice numbers. Get it to the track now.
I guess we have tuff dynos lol.
