406rwhp/460tq
Old Mar 31, 2007 | 07:47 PM
kill_machine85's Avatar
Default 406rwhp/460tq
Hello, I just wanted to get the your guys opinions on what do you think of my numbers with my mods except for suspension and weight reduction. I havent got it to a track yet. It was dyno tuned at Strictly Performance Motorsports here in Cali.
Forged Iron Block 370
Diamond Pistons -2cc,9.5 to 1 compression
Callies Compstar Rods, Mellings Lifters
Comp 236/232 on 112
TEA Stage III Judson Port Heads, 2.1" Intake 1.60" exhaust
74cc Chambers
Patriot Dual Springs/Retainers 330 cfm+intake O-ringed
QTP Stainless Longtubes and Y-Pipe
Motoron 60#'s A1000 Inline Fuel Pump Speed Inc Rails and Regulator
Fast 90 Nick williams 90 TB
Double Roller Chain, Ported Oil Pump, Comp Pushrods, Meziere Race Pump
ATI Balancer, Alternator Only, PS and AC Removed
Everything is ran through a PTC built TH400 RMVB with T Brake
Yank PYE 3600 converter Hays Flexplate
Downside is 2.73 rear with MT 275/50's
I got the car dyno tuned alittle while ago and i got 406 RWHP and 460RWTQ does that seem about right or a little low?
Old Mar 31, 2007 | 07:57 PM
ArrestMeRed99Z28's Avatar
My guess is that this motor doesn't perform well up top, but I'd like to see the graph. IMO it is because you are running such a low compression, I think if you milled the heads down to 66cc or so to get more compression and still run well on pump gas, and it should perform much better up top. Then you're gonna have to start saving for a new rear end, and then you have your pick of gear ratios.
AJ
Old Mar 31, 2007 | 10:08 PM
yeah i know the compression is lower becaue it was built with the intention of usinf FI, and yeah i know i need a rear here soon, it wont hold up forever.
Old Mar 31, 2007 | 10:11 PM
HUNTER02SS's Avatar
Are you planning on forced induction.I was wondering because of the 60lb. injector's.I have a 370 with 8.5 -1 compression for my turbo's and made the same #'s,but i have stock injector's in mine.I will be running those 60lb. injector's with my turbo's.
Old Mar 31, 2007 | 11:10 PM
Yeah im planning on going force induction, it was originally built in mind of using a large turbo, but i have recently been thinking about a F1.
Old Mar 31, 2007 | 11:17 PM
Specialized's Avatar
That seems like very solid numbers, considering your low compression ratio.
Old Apr 1, 2007 | 12:06 AM
bad95killer's Avatar
Nice numbers with your current setup buddy
peace
Old Apr 1, 2007 | 07:48 PM
Kraest's Avatar
Wrong cam, too much injector for a NA setup, and not enough compression.
Good numbers for a turbo-motor
Bolt that sucker up and see what she does
Mike
Old Apr 2, 2007 | 12:18 AM
unforunatley i need to get that rear before i go force induction
