Trickflows + TR230 cam dyno
Old Apr 1, 2007 | 01:58 PM
pdd's Avatar
pdd
very nice-its nice to see someone with a medium size cam with these heads instead of donkey dick cams like already said, put a thinner head gasket on-maybe itll raise the torque a little
Old Apr 1, 2007 | 07:44 PM
Kraest's Avatar
Originally Posted by Patrick G
Glad to see more independant results of TFS heads.
Old Apr 1, 2007 | 10:00 PM
JRracing's Avatar
Congrats man. I wish I still had my tr230/224. I was very pleased with it on stock heads. I never tested it with ported heads. Mine made 390rwhp with a cut out and all other supporting mods.
I bet you could have went tighter with the compression. haha.
Old Apr 2, 2007 | 01:18 PM
PunkNPonys's Avatar
Congrats on the new found power. I am also glad to see more numbers with those heads and a different cam.
Old Apr 2, 2007 | 06:19 PM
98darkbird's Avatar
Man I bet this car is a screamer.....lets see some track times
Old Apr 2, 2007 | 06:22 PM
bshell's Avatar
Thanks, it does get up and move when I let it! I will take it to the track soon. I'm still a track novice and just hope I can get a decent mph to go with the power I'm making now!
Old Apr 5, 2007 | 09:04 PM
steve98ta's Avatar
Nasty numbers thats sick! What length pushrods did u use?
Old Apr 6, 2007 | 06:42 AM
KONG's Avatar
Nice numbers brian....
Old Apr 6, 2007 | 06:45 AM
BlackScreaminMachine's Avatar
Internet Mechanic
WHen it comes time for heads its either wait for Small Bore L92 or TFS.... mmmhmm
Old Apr 6, 2007 | 09:36 AM
KONG's Avatar
Get the TFS 215cc because there is no way you could utilize all the airrflow of the L92's unless you had a max effort 346. Just my .02.
Old Apr 6, 2007 | 11:11 AM
SIC LSX's Avatar
how do you think the MS3 or MS4 whould be?
Old Apr 6, 2007 | 12:58 PM
  #32
KONG's Avatar
Nothing against those cams but they are a BIT PEAKY. I think anyone who is really serious about having a fast, drivable car who's power doesn't start at 4500 rpm should get a custom grind specifically for their application. Just my .02.
Old Apr 6, 2007 | 03:40 PM
  #33
RIDINFILTHY's Avatar
what kind of timing are you running to stay safe!!!!
Old Apr 6, 2007 | 04:09 PM
  #34
jeffstar's Avatar
Good work man. I love my Trick Flows from TEA!
Old Apr 6, 2007 | 07:00 PM
  #35
bshell's Avatar
I'm running 28-29 at peak hp, 24-25 at peak tq with no hint of knock. My car has always tolerated a good amount of timing. The AFR is where I tend to be cautious, with 12.4-5ish at peak tq and 12.9 to barely 13.0 at peak hp. Peak hp was going up everytime I leaned it out, but I decided to stop just under 13.0. This was measured with my wideband installed in the driver's side O2 bung (Open Loop tune).
Old Apr 12, 2007 | 07:24 PM
  #36
gillbot's Avatar
mine made 399 through stock heads, threads like these make me want to get a set of heads even more!
