Trickflows + TR230 cam dyno
Ended up with 455hp / 399tq. I could have squeezed a few more out of it, but I ran out of time. Mods are in my sig and the heads were milled to 61cc and installed with HS roller rockers and stock head gaskets. Overall, I’m really impressed with the gains I picked up with these heads.
My last dyno was with ported stock heads (stage 2). Those heads flowed well at peak lift on the intake, but low on the exhaust side and at mid lifts. With those heads I made 423hp / 371tq.
With the Trickflow heads I gained 32hp and 28tq at peak, but I like the midrange gains even better! Here’s a graph of my old ported heads vs Trickflow:
![](http://img90.imageshack.us/img90/3958/pictureui1.th.jpg)
solid gains for just a head swap and adding HS rockers. (just head swap right?) you could probably pick up some more power by running a tighter quench and some more tuning. congrats man.
Jon
Jon
Originally Posted by gyrene2003
not bad, but if u put a turbonator in that thing ull be at atleast 700hp!!!
Originally Posted by lilbuddy1587
As far as the power goes, nice man! I'd have ran some thinner gaskets for a little more compression(PtV would have been ok, but always good to clay) but still impressive! power under the curve is great man, I'll bet it runs like a raped ape with those 4.10's! I'd say without those gears you'd be around 465-470ish/410
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
peace
Originally Posted by NoGamesLS1
what were the other heads you were running?
Found this in one of his other posts
Ported stock heads
The heads are unmilled and spec'd out with 68cc combustion chambers and 244cc intake chambers. They have 2.02" int and 1.57"exh valves. They flowed 303cfm intake, 195cfm exhaust at .600.
LS1 Tech Administrator
Very nice gains over you old heads. The added compression makes a big difference too. Glad to see more independant results of TFS heads.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Congrats on the new found power, looks like very good gains compared to heads that had already been ported.
The torque numbers do look low, could be a function of the reverse pattern camshaft.
Proper exhaust scavenging yeilds best power, slightly more than what is needed yeilds increased torque, so anything you can do to help the exhaust side should net you more torque.
I saw your post about dyno testing your other heads, looks like you have been BUSY. How long were the other heads on your car?
Originally Posted by Irocss85
aha. found it. great gains. is that mustang or dynojet?
did you happen to check piston/valve clearance? know someone thats thinking of goin with a cam that size but wonder if we can mill the heads and go with thinner gaskets too.
Hahaha! I was pretty busy last week! The old heads have been on for the past 9 months or so. I just never got around to dynoing them until recently.
I have pacesetter headers and a pacesetter offroad y pipe (for extra ground clearance) with a magnaflow catback and a cutout. I know the reverse split is more picky about exhaust flow. I'll probably run this cam for a while as I really do enjoy it, and then move on to something a little bigger with a traditional split (nothing wild though). Nearly 30ftlbs at peak and gains at every point on the curve over a set of already ported heads is what I like!
Originally Posted by Patrick G
Very nice gains over you old heads. The added compression makes a big difference too. Glad to see more independant results of TFS heads. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
good deal! It has some more in it with some more tunning
I would like to see what i would pick up with these when i get them and a ported match vic jr! Im a cam only on stock 99 heads with 231/237 cam
Im at 413/380 now
