Uhh Ohhh, Vengeance doesnt break 500rwhp........
Originally Posted by Ron@Vengeance
Your comments in EVERY thread I post are not only not wanted, but do nothing for the content of the thread...
Why dont you bring your lil C5 over and see if it hits 530 on our dyno... I have a feeling it might hurt your feelings
Find a hobby
Find a hobby
My dyno numbers were done on a factory-calibrated 248 Dynojet, not a flashed and reflashed and reflashed 224
I have nothing against you or anyone else on this site. You simply aren't going to make 383ci low-end torque with a 346 and a 240/244 cam. :shrug:
Kudos
Originally Posted by brad8266
^^^ Funny because I made 385 lbs-ft @ 3500rpm's on my 346CI engine with a 232/236 cam, wasnt on a dynojet either.
385 lbs-ft with a 232/236 and a 346ci is normal.
Originally Posted by Kraest
How is that funny? Obviously you missed the point
There are a number of big cams out there that are making big power down low. Many of these werent done at Vengeance too.
You're still missing the point. :shrug:
We're talking about 440-450 lbs-ft with a 346, not 385 lbs-ft.
And this is a factory calibrated 224x that is 10 months old.. Good try though ..
It won't hit 530. It'll hit about 560.
Kudos
Kudos
Thats the problem, you are spending so much time behind your keyboard you have gotten left behind the times... there are TONS of cars out there making 440rwtq with heads/cam....Dont worry though, you are still superior with your stroker motor
#39
I dont see Karest with that small of a cam making that much power out of a 408. Its all in the set-up but there are 408s with perfect combos making that power with much larger cams, and aftermarket heads.
Ron, you mentioned you couldnt go all out on this combo, what is different from this car to any of the others that hit or went over the 500 mark?
#40
hrmm.... exactly what is wrong with a stroker motor???
