Guestimate on 383 #'s
HSC Built 383ci LSX V8
4" Eagle crank
Eagle rods
Ross Pistons (11:1 CR)
Race bearings
AFR 225 heads with spring upgrade
DRE Rev Kit - Hydraulic roller
Comp Cams Custom Grind
ARP Head studs
Cometic Gaskets
LS6 Intake
Ported GM Throttle Body
ASP Underdrive Crank pulley
It also has full length headers and a 3.5" single exhaust all the way out.
They have rwhp estimates at 475, but due to the shitty tires on it (225/50/16 crap radials) it was spinning on the dyno.
Going of that basic list above, does their estimate sound about right? Also, I do not have the cam specs as they aren't listed. I can also imagine that a FAST 90/90 setup would be a lot more suitable than the LS6 intake as well.
Thanks
Can make a guess on power either, thats just as important as motor size.
Thanks for the replys though.
