520rwhp 418cid A4 PRC CNC L92 Results
Originally Posted by squealingtires
what's the SCR and DCR for that combination?
Originally Posted by Jason 98 TA
520rwhp in a a4 through cats seems pretty damn good to me. At 11:1 the car drives awesome & works really well with a tiny 2800 stall!
Still curious about the DCR for that camshaft? Thats a really nice looking torque curve.
Originally Posted by KAOS
this is nearly a 550+ rwhp car through a 6 speed. i think this is an absoulty beautiful thing. i still dont see many cathedral port cars making that kind of power per dollar. so what king of price tag does this combo carry?
damn .... I cant wait to slap my HKE/Greg Good combo together! Personally I dont give a rats *** if it only does 500rwhp..... it better make 800 on the hose though!
Good numbers fellas!
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Very nice through an auto. I bet in a m-6 it would be a street beast.
On a side note TSP builds a great motor as well as anybody. I have had 3 builds from them and I tried to tear up the last one just to justify a big stroker build up. All 3 build-ups were impecable and made the power they told me to expect.
Originally Posted by gator's 99TA
lost cause, do you understand how a bigger stall converter never locking up going through a 4L60e can not in any way compare to your dyno queen drlveline?
surely your joking??? if not.... you must have been drunk.
i didnt realize a corvette IRS and a mcleod street twin clutch with steel flywheel was in any way shape or form a "dyno queen"
as far as budget and dollar per HP.. this is not exactly a "low cost" build... this a freaking 418 guys... a 418 with heads that flow more than most ported cathedral ports right out of the box untouched...
im not debating this car is not wicked, or that it doesnt make power or that its not a cheap and very effective build... i just dont understand why exatly these engines arent making more power than this..
if somebody would like to explain to me how 10 more cubes than me, and heads that flow wicked good, and an intake that flows wicked good.. is only netting about 20-30 more rwhp than my setup (my setup is budget to the highest extent of the word minus the shortblock) im all ears to hear the reasoning..
not saying it doesnt make good power.. just saying i would expect more... i am yet to see any of these monster ported cars hitting 580-590 RWHP... which is what id expect for those flow numbers and those cubes with all the supporting mods.
wow, a street twin disc. impressive. better run 10.50s or better with that dyno lost cause. do i need to make a post of how many times you have gone into posts that deal with L92 stuff and ridculed it? wait, thats a real lost cause. you have seriously got caught up in flow numbers and making sure everyone realizes your car spins the dyno rollers REALLY fast.
making over 500 rwhp with a 3500 stall automatic is a damn impressive setup. you obviously have no experience setting up or tuning an auto car to race.
#32
Just think if we put a little more camshaft, 11.8 compression, ported l76 intake, electric water pump, and a ASP pulley on that thing. It's easy to see where 580 is doable, but sometimes max power isn't what the customer is after.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
#33
LS1TECH Sponsor
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#34
I think I can explain it to you. Your cam is larger & this car is 11:1 compression. Keep in mind I built this thing to run good behind a TINY converter. I have no doubt I could build a 580rwhp one if someone wants to be a little bit more radical & send me over the cash money to build one up the way I'd like to run one. I have many other camshaft designs sitting here that I haven't mentioned, but that worked pretty well on the engine dyno.
thanks for the reply
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#37
You said that it was designed to work with a 2800 stall....did your customer change the stall because your original post states a 3500 stall? I think the numbers would look even better with the 3500 vs 2800 stall.
