LS2 403 F1A results
Old Apr 30, 2007 | 01:40 PM
  #41
slow3hoe2's Avatar
stop picking on stock r1's with ur monster
Old Apr 30, 2007 | 02:32 PM
  #42
Damyonn's Avatar
Old Apr 30, 2007 | 03:18 PM
  #43
silver01z06's Avatar
grats on the power. always nice to get more than expected. it pays off to buy quality parts.
Old May 1, 2007 | 06:24 PM
  #44
VINCE's Avatar
Shorty Director
Nice!!!!!!
Old May 2, 2007 | 08:26 PM
  #45
98Z28CobraKiller's Avatar
Restricted User
Awesome. Why are the cam specs not revealed?
Old May 2, 2007 | 11:45 PM
  #46
TNTramair's Avatar
very very nice!! subscribing...anxiously awaiting pics and/or vids...
Old May 3, 2007 | 01:03 AM
  #47
GrannySShifting's Avatar
Where your goals for more torque from your setup or a peakier combo like that? A ton of power for the street for sure!
Old May 3, 2007 | 06:52 AM
  #48
speedracer5532's Avatar
My goal was to hopefully have a good realible setup with lots of power. So far I have exceeded my goals and couldn't be happier with the results. Now if I can just drive it to the track on pump gas and run a high 9 things will be perfect.
Old May 3, 2007 | 07:21 AM
  #49
TrentSS's Avatar
Default Awesome power!
John,
Incredible results man! To be able to put something like this together, doing it yourself, has to be a great feeling. May I ask, how in the world are you going to be able to harness 864 rwhp on the street ? I couldn't imagine trying to hook that thing up on the street...
Old May 3, 2007 | 08:13 AM
  #50
Originally Posted by TrentSS
John,
Well I don't even try to hook it in first or second gear even with drag radials. I can usually always hook it in third.
Old May 3, 2007 | 09:49 AM
  #51
BADSZ28's Avatar
Incredible man. What is your pulley set-up? Cog or 8 rib or...? Does that blower fit without any modification to the car? Still have all accesories? Was it a kit or a custom set-up?
Old May 3, 2007 | 10:00 AM
  #52
I am running the ATI 7.625" 8 rib crank pulley and a 4.75" blower pulley. The bottom of the radiator has to be moved forward as much as possible to be able to fit a 4" elbow on the blower for the inlet and right now I don't have A/C on my car. No room for the stock condenser. I would like to be able to get a custom a/c condenser and put all the a/c back on. I ordered everything from Bob at Exotic Performance Plus and pretty much everything fit great.
Old May 5, 2007 | 04:06 PM
  #53
Here are some pics for you all to enjoy.
Old May 5, 2007 | 06:49 PM
  #54
eb02z06's Avatar
Very nice #'s bro-what does your fuel system consist off?
Old May 5, 2007 | 07:18 PM
  #55
Racetronix dual in-tank pumps from Lonnies Performance, #8 supply line to a y-block, aeromotive fuel rails, 60lb motroton injectors, aeromotive boost referenced fuel pressure regulator, and factory supply line used as return line.
Old May 7, 2007 | 03:41 PM
  #56
Wonderbread's Avatar
Wow great numbers!! Where is your injectors duty cycle at with those 60lb. injectors with that kind of power? I would think that would be pushing them close to the limit? I am looking a an injector calculator (Accell DFI wheel fwiw) and even at 900 FWHP it is reccomending an 83 lb injector!!
Old May 7, 2007 | 09:01 PM
  #57
My 60 lb injectors are definitely maxed out. 120% duty cycle but my afr is still good. I have turned my fuel pressure up some which has helped. I do plan on most likely going with 96lb injectors and an impedance converter.
Old May 7, 2007 | 09:19 PM
  #58
rbrcka's Avatar
BRUTAL! That is awesome man
Old May 9, 2007 | 11:54 AM
  #59
Benjamin Russick's Avatar
Great numbers and badass car! You are going to hit nines no problem if you can keep it away from the wall...
Old May 14, 2007 | 07:14 PM
  #60
Restricted User
Remember that the wideband is reading an entire bank or even both banks depending on sensor location. So AFR being good does not mean that all cylinders are good. I think that changing the injectors will also net you more power.
