vengeance racing built 416! predictions
Old May 27, 2007 | 03:58 PM
osuqsz06's Avatar
Default vengeance racing built 416! predictions
ok fellows!! my car is near done!! its an 02 ss m6 with the following mods=
vengeance built l92 416
tfs 225's
256/262 .598 .598 1xx cam
fast ported 90/90 umi tbody
arh 1 7/8 hears, catted y, corsa
spec 3+
elect. w. pump
pulley
steel d.s.
moser 9 w/ 3.73's
etc.
i have a sartup vid =https://ls1tech.com/forums/showthread.php?t=721653
car sounds amazing through cats i was shocked!! i will have dyno vid and numbers late tuesday night!!
what are your predictions????
Old May 27, 2007 | 04:10 PM
smok'nZ's Avatar
MASS seller approved
540+ let us know
Old May 27, 2007 | 04:43 PM
Big-DEN's Avatar
Electric WP.
+ TFS 225. The TFS have been doing well on the 346.
My guess.
560rwhp-580rwhp
Old May 27, 2007 | 07:43 PM
KAOS's Avatar
Originally Posted by Big-DEN
Electric WP.
My guess.
560rwhp-580rwhp
Old May 27, 2007 | 08:27 PM
Smokinstorm's Avatar
Old Drag Racer
If you went with enough compression I'm sure 550+ is going to be a piece of cake.
Old May 27, 2007 | 10:29 PM
TXZ28LS1's Avatar
wouldnt surprise me if it was close to 600 hp or so. vengence has been making some sick power with there setups lately!! good job vengence!!
Old May 27, 2007 | 10:53 PM
Big-DEN's Avatar
Only reason I didn't give 580+ was Fast90 intake, though there have been some setups that do make it IE: 447 cubic inches.
This a 416.
The TFS heads have been making notably more power and TQ on the 346 - IE: vengence cracking 500rwhp, and more impressive over 450rwtq out of 346 cubic inch. Used to be a 383 to get that rwtq range... Have to say Ed C has also made these numbers too, but still not common.
There was a combo on here that mad 560rwhp with a ported LS6 head, why I gave it over this, since the TFS225 + electric WP + vengence racing... 580rwhp is possible. Think should be over 550rwhp FOR SURE, due to vengence being on the project.
Old May 28, 2007 | 12:13 AM
JakeFusion's Avatar
Super Hulk Smash
It has Cats though... and a Y-Pipe.
True duals and no Cats with TFS 235s and I'd bet 575.
Cats + Y + 225s = 540.
Old May 28, 2007 | 12:21 AM
osuqsz06's Avatar
thats what im expecting!
Old May 28, 2007 | 01:59 AM
Ron@Vengeance's Avatar
530 to 560rwhp with insane torque thru the ENTIRE rpm range is my bet ... The choke point in this combo is the intake/exhaust... 346s can survive off of the FAST and a Y pipe... It takes more air to feed a stroker to make the BIG peak #s....
Glad to see it is running Mike!!! We are looking forward to some good results. Give me a call before you put that thing on the dyno!!!
Old May 28, 2007 | 03:55 PM
osuqsz06's Avatar
thanks!! ill give you a call in the morning.
Old May 28, 2007 | 04:03 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Subscribing for results
Old May 28, 2007 | 04:06 PM
Fratsit's Avatar
Sitting in the stands watching.....
Old May 28, 2007 | 07:37 PM
SLowETz's Avatar
Hhhmmmm.......
My Vengeance 416" went 538/500 w/no street miles on a heavy *** driveline(TH400/ss3600, steel DS, 12 bolt/4.10's on a 28" slick).
I think you'll do better w/a slightly bigger stick(5-8 rwhp?), M6/light weight clutch(20+ rwhp?), and a 3.73 gear(8+ rwhp?)....
I know you can't stack/add individual components for a rwhp number, but given what I've seen these guys do........
I'm gonna say 570/527ish +/- NA on this build-
Good luck!
Old May 28, 2007 | 08:31 PM
osuqsz06's Avatar
Originally Posted by SLowETz
Hhhmmmm.......
Good luck!
i hope so!!! sweet ride man i saw pics of it at the g11 pic thread!! gotta get some of those valve covers!!
Old Jun 2, 2007 | 09:59 PM
osuqsz06's Avatar
alright guys i got some numbers!! found out the hard way you cant really expect maximum power out of a stroker w/ a y pipe!!
496rwhp
452 ft ilbs torque
again thats through cats and a 3 inch y pipe
the crazy thing is we removed and ran open headers (tuned for full exhaust) and picked up 56rwhp and 50 ft ilbs torque!!! and that was without tuning as well!!
so its obvious i need true duals and that 520+rwhp wont be to hard to hit.
i never realized that the y would choke me up that much.
however, the car had 430 torque at 3k rpm and its a blast on the streets
i will get dyno graph up soon as i left it at the shop!!
again, i wanna thank mike and ron at vengeance for building me a killer street setup!! and for offering all the help i needed and then some for this project!!!!!
Old Jun 2, 2007 | 10:02 PM
MPHmotorsports's Avatar
WOW thats a lot of power to be lost through the exhaust.
Its acturally quite funny.
Do you have a Y pipe or T pipe? is it a hooker Y?
Old Jun 2, 2007 | 10:13 PM
osuqsz06's Avatar
its a 3 inch y pipe. i dont wanna name the brand. im not tryin to slam the company. but i know they work well w/ heads and cam cars. but honestly w/ a stroker its just not enough.
Old Jun 2, 2007 | 10:22 PM
Weird. I had a 402 camaro on the dyno and with a SLP "y" pipe it make 502 through a magnaflow exhaust. We opened the cutouts which he had cut the Y pipe and added dual 3" cutouts in the straight part right after the header and picked up right at 20 HP. A impressive gain still.
I don't think you would hurt the rep of a company naming a name. The one I think is garbage is the hooker. It is more of a "T" then a "Y"
Picking up that much power makes me
Old Jun 2, 2007 | 10:24 PM
Congrats on the #s Mike!!!! 540/500 opened up isnt too shabby .... I honestly didnt expect to see that much of a gain either.. I guess the exhaust is a lil more restrictive than we thought it was.... Nothing like cats/Ypipe/restrictive catback to ruin your day!!
Looking forward to you getting your duals and coming down for a final tune at our place... Im QUITE confident we can get 550rwhp outta your lil street motor
