408... Should I be disappointed?
When I bought the car, the previous owner gave me sheets where he made 466/466. However, his sheets were not SAE corrected.
There are no problems with the motor for sure, new valve springs, plugs, and wires. Did a compression test and a leakdown, everything showed fine. I recently ran a 12.2 @ 119 on street tires as well. What do you guys think about all this? Should I be happy with it for the time being? I know when I throw a set of heads and an intake on it, it should make a huge jump, hopefully over the 500 mark. Let me know what ya'll think. If you need any other info, lmk. I'll scan the dyno sheet later on today.
Thanks,
Alex
The car has no cats. I know the car needs heads, intake, and probably some 1 7/8'' headers to make the big number, but for what I have right now, do those numbers seem ok?
60' was 2.079.
Smok'nZ, I believe the other car you were talking about that made 467, is mine. I bought it from a moderator on here about a year ago.
And yes Brian, defintely time for some Trickflows and a Fast 90.
I never knew the 466 was with the 10 bolt. I wish I would've known that a loooong time ago. Also the car has a twin disc clutch now and is without an U/D pulley which it had then (had belt eating problems and it had to go).
