Critigue my Setup on TFS 225 Heads
TFS 225 Heads
Jessl 1.7 rockers
PRC Extreme Gold Valve Springs
FAST 90 Ported Intake
Nick Williams 90 TB
248-252 Dur 650 lift 112 or 110 Lobe Sep
42lb Injectors
Kooks 1 7/8 Headers
3 1/2 X-Pipe
Yank PT4400
Stock 10 bolt with 3.42 gears
The goal with the car is to still be Streetable. Looking to run 6.80s in 1/8 mile @ 101 mph N/A.
Does this combo sound right to help me reach my goals? Please suggest any items that I can change on my setup to help me reach my goals with this car.
Thanks Everyone
Seb
TFS 225 Heads
Jessl 1.7 rockers
Nick Williams 90 TB
42lb Injectors
Kooks 1 7/8 Headers
3 1/2 X-Pipe
Yank PT4400
Thanks Everyone
Seb
The PRC Gold springs are 2 steps down from the standard spring that TFS puts on their heads, so that's a big NO-NO.
I would go with the Vengeance Vindacator cam or the ECS cam, both are proven 500 RWHP cams with the TFS 215's, everything else looks great to me. Hope this helps.
Good luck, that is one nasty bitch you are putting together!!
I think your exhaust choice is a little excessive. I think it would perform and fit better with 1 3/4 longtubes and 3 inch duals.
I agree with the valve spring deal. TFS springs are I believe PSI springs. They are very nice and have excellent pressures. The cam is quite large for a head that is somewhat efficient. Whatever cam you do decide to go with grind it on a 108 or a 110lsa. It will run up top as well. Cutting it on a tight LSA brings the horsepower and torque curves closer together. it wont kill your top end pull.
Streetable? Thats all relative...
With that in mind, it can survive in an auto for a while.
Regarding being streetable, I think your over camming. I was running a little old 224/224 .535 .535 with great success. It doesn't take that big cam to run good as long as the rest of the setup is dialed which it looks like you have most of it covered.
347 Forged Rods & Pistons New Rebuilt Stock Short Block
TFS 215 Heads
Jessl 1.7 rockers
Nick Williams 90 TB
Vindicator Cam 240/244 .608/.596 112+4
42lb Injectors
Kooks 1 3/4 stepped 1 7/8 Headers 3inch Primary
3 inch True Duals
Yank PT4400
Stock 10 bolt with 3.42 gears (FOR NOW) Will upgrade when money allows to 12 BOLT w/4.10 gears, But going to have to run the 10 bolt for now
QUESTION???? Should I mill the TFS Heads to 59 CC for more Compression. I am going to be running a 150 shot on this setup?
What kind of piston are you running? Dished/domed/valve reliefs?
