Patriot Heads dyno Numbers?
Old Jul 6, 2007 | 03:23 PM
striker754's Avatar
Default Patriot Heads dyno Numbers?
What all have you guys been getting on the Patriot stage 3 ls6 heads with a fast 90/90 and a fairly large cam and a t56?
I haven't seen too many dyno/track results. The ones I have seen look nice, but I want to know if they are something special with teh setup or what. They have a nice flat torque curve and put down a max of 473/425 peaking about 6200rpm. 400 ft*lbs at 3000rpm too
What are you guys getting with them, preferrably with the cam around 23x/24x >.600
Dyno sheets are great
Old Jul 6, 2007 | 04:10 PM
Emoney97ss's Avatar
I second this i'm about to order some heads patriot or prc's or maybe a used set i just can't make up my mind...
Old Jul 6, 2007 | 04:36 PM
Tri5Nerd's Avatar
Old Jul 6, 2007 | 05:42 PM
Mr. Luos's Avatar
I have that set-up....but it is over a TSP 402.
Old Jul 6, 2007 | 10:06 PM
Thule's Avatar
i got this set up, stageII ls6's, 59cc,ls6 multy layer gaskets, extreme lift springs, ls7 lifters, 226/226 585 112LSA cam, FAST intake NW 90mm TB,updated knock sensors, 85mm maf, pacesetter lt's, non catted y pipe, loudmouth exhaust, and more.. M6 car with stock 10 bolt,
no dyno numbers yet, am i wrong to hope for 420ish?
Old Jul 6, 2007 | 10:58 PM
JoeyGC5's Avatar
With the original LS6 style heads, a 224/0.581 lift/112 cam,11-5/8 longtubes, no cats, LS6 intake, and slp loudmouth for a C5 I made 428rwhp and 405 rwtq.
Old Jul 6, 2007 | 11:39 PM
Thule's Avatar
that gives me hope
Old Jul 6, 2007 | 11:44 PM
Emoney97ss's Avatar
i want to know what a patriot combo will do with a large cam... say one that will put you at 400 without heads...... should a good head net you somewhere between 50-40 horses? ive read where h/c have givin ppl a whole 100 so why wouldn't that be possible
Old Jul 7, 2007 | 12:45 AM
Thule's Avatar
i want to know that to.. somehow i am afraid that with the 226 cam my goals just dont get reached, so i am looking at the MS3/MS4, shouldn't that be over 450rwhp?
but if my set up gets me over 430rwhp, then i i dont have to think about it
Old Jul 7, 2007 | 01:01 AM
ThaBirdMan's Avatar
through an auto got almost 430
Old Jul 7, 2007 | 01:47 AM
Thule's Avatar
awesome!
more info please
Old Jul 7, 2007 | 02:12 AM
PREDATOR-Z's Avatar
Moved from internal, this is a dyno question
Old Jul 9, 2007 | 12:59 PM
JakeY2KZ's Avatar
Using stage2 5.3 heads but I'm sure you could get more out of the LS6 heads and bigger cam. Mods and numbers below.....
