View Poll Results: What dyno number rwhp?
390
2
4.65%
380
21
48.84%
370
12
27.91%
360
8
18.60%
Voters: 43. You may not vote on this poll
Dyno Numbers from M6 to A4
Old Jul 18, 2007 | 02:54 PM
99 Pewter TA's Avatar
Question Dyno Numbers from M6 to A4
What do you think they will be?
M6 was 407rwhp/375rwtq. Mods are in the sig.
Old Jul 18, 2007 | 03:16 PM
MikeD101898's Avatar
Take off 6%. So about 382.
Drivetrain loss with M6 is about 14%. A4 is about 20%
Old Jul 18, 2007 | 07:24 PM
1989GTA's Avatar
I was going to say 385rwhp.
Old Jul 18, 2007 | 07:32 PM
gator's 99TA's Avatar
i would guess 365-370 rwhp if your converter is unlocked and decently efficient. i went from a t56 to A4 and went from 385 rwhp to 340 rwhp. no other changes made. i ran a yank 4000 that was not very efficient.
Old Jul 19, 2007 | 09:33 AM
N4cer's Avatar
It's not going to be a percentage. That's just silly. That would be like saying a 300hp car only uses 30hp to turn a TH400, but a 1000hp car uses 100hp to turn one. That's just not right. It'll be closer to a flat number loss.
And I only lost 20rwhp locked and 30rwhp unlocked on my 4L80e swap... but the tune changed. I was on my 24* nitrous tune on the M6, and was on 29* NA tune on the 4L80e. So really we don't know. Just wanted to tell the story I guess.
Old Jul 19, 2007 | 10:17 AM
i agree. its not a percentage. i lost 45 rwhp on mine. i did gain 2 mph in trap speed and lost ET!
Old Jul 19, 2007 | 01:38 PM
DannoWS6's Avatar
Going to a 4l60E w/ a 3800 stall, I'd guess around 370 locked.
When I had my old 3500 stall put in, just that ate up 25-30 peak hp.
Old Jul 19, 2007 | 09:02 PM
Thanks for the replies. Its getting dyno tuned on Tues. I'll post the results that night.
Old Jul 23, 2007 | 01:39 AM
nine-eight's Avatar
Actually, everything ive learned about motors makes me agree with this guy. it will be a certain percentage, as the faster you try to accelerate the components inside of your transmission/rear end/driveshaft the more resistance you will encounter. the key is that you arent just turning the components, when you add more power you are trying to accelerate them at a much quicker pace and the more and more you try to increase the acceleration the more power it will take. Ive heard of percentages being used quite often when calculation drivetrain losses. and I think mike's about on the button with ~20 percent total loss. JMHO.
Nine-Eight
Old Jul 23, 2007 | 07:24 AM
edcmat-l1's Avatar
Nine-Eight
If your calculations are correct, then what do you suppose absorbs the additional 6%? And furthermore, if you lock the converter in an auto, then how does that affect your calculations?
I believe locking a converter makes the auto results damn near identical to a clutch car.
You think the guts of an auto trans is that much harder to turn than a 6 spd?
Remember the drivetrain is going to remain the same.
As stated above, I'm in the belief that its a set amount of loss, a percentage, but only to a point. Again, I agree that a 1000 hp car wont loose 200 hp. Which is what it would be by your calculations of 20% for an auto. That would be like drive with the E-brake on.
Old Jul 23, 2007 | 06:40 PM
OneQuickCoupe's Avatar
Are we still testing tomorrow? Good luck. I'm going with the 370 guys.
D.J.
Old Jul 24, 2007 | 10:31 AM
SPRAYED 01's Avatar
same dyno same mods but i did 428hp m6 and 372 unlocked 4l60e with 4k stall. went faster at the track though. which is all that matters.
Old Jul 24, 2007 | 11:23 AM
How much did you pick up at the track going to the A-4 and 4K converter?
D.J.
Old Jul 24, 2007 | 10:33 PM
1989GTA's Avatar
OK, we are well into Tuesday night. Any results?
Old Jul 24, 2007 | 10:46 PM
6-Speed Terror's Avatar
on mine i went from 347 hp with no headers and the patriot 226 cam to 355 with headers and ms4 unlocked, i was dissapointed but i want to go to the track to see how my times change hopefully that will get me happy
Old Jul 25, 2007 | 08:58 AM
Sorry about that. I may have some tranny issues. The tuner told me the car would hold until 3300rpms and the then "blew through." So I couldn't get it dynoed. At 3300rpms it was at 330rwhp. I guess he couldn't get the converter to lockup in 3rd. I am not sure how they dyno A4 cars.
Old Jul 25, 2007 | 09:00 AM
I may go out to HRP this weekend, maybe Sunday there will good weather.
Old Jul 25, 2007 | 09:25 AM
DannoWS6's Avatar
He could of done a pull unlocked anyways if you wanted. The lockup clutch might just be slipping or not engaging. You're not blowing through the converter at your power levels. How many miles on the tranny/converter?
It should still perform well at the track.
Old Jul 25, 2007 | 10:25 AM
mattraypharbor's Avatar
340rwhp unlocked...
Old Jul 25, 2007 | 11:36 AM
~1200 miles. The shifts fine, but going 2 to 3rd it will drop back down to 2nd if I let off the gas fjor a second. I got on it last weekend and it shifted through all the gears at 6500 with no problems.
