Guess my HP/Torque
Adding on a TR224 112 Cam 0.563 lift
Patriot Gold Dual Springs + Titanium Retainers
LS2 Timing Chain
Hardened Pushrods
March Underpulley + Alternator Overdrive Pulley
349hp/359ft/lb at the rear wheels with current mods:
Mods that affect HP/Torque
LS6 intake
Ported TB
SLP Lid
QTP 1 3/4 HVMC Longtubes ceramic coated
Magnaflow 3 inch cats
2.5 inch true dual stainless steel mandrel bend with x pipe
3 inch Solo Performance full mufflers
LS7 clutch/LS2 flywheel
315/35/17 BFG KD on Polished Aluminum 17x11 ZR1 rims
Lesser degree mods
MSD wires, TR55 plugs, EGR restriction removed, TB coolant bypass, free ram air, K&N filter...
I'm thinking 380HP and around 375 Torque all around...
Mind you my first and foremost goal was a cam that was more streetable than trackable, I'm probably going to spend 99% of the time right at that 1700 range the power starts at as that's my normal cruising rpm.
