diff between STD and CORRECTED dyno #'s
Old Jul 29, 2007 | 12:24 AM
NHRArox's Avatar
Default diff between STD and CORRECTED dyno #'s
whats the differents plz
-ben
Old Jul 29, 2007 | 07:39 AM
GuitsBoy's Avatar
The correction factor attempts to adjust your HP number for weather conditions. If you dyno on a very cold day, your corrected number will be lower. If you dyno on a scorchingly hot and humid day, the correction factor will bump your score up a bit. Its a way to standardize HP numbers so that you will run similar numbers on two very different days (weather wise).
Old Jul 31, 2007 | 07:37 PM
Mike @ New Era's Avatar
STD is an older sae correction , and will correct the numbers resulting in a higher horsepower and torque number in your graph .
Mike
