Why do dyno runs usually start at high rpms?
I'm interested in low end and area under the curve. I want to know just how much I am giving away down low for gains up top, but this info is very hard to come by.
Is there some technical reason for all this, does nobody else care, or what?
If you have a high stall converter, you'll never be at 2500rpm and WOT with the converter locked without a manual switch, so anything under the stall speed is fairly irrelevant.
As far as being able to lock the gear/torque converter, certain year cars you can, some you cant. I typically start test for the six speed auto vettes at lower (2200RPM) rpms because fourth gear is a 1.15:1 ratio, and by 6400rpm you're doing 160mph or so.
If you are looking for area under the curve, why are you interested in areas not under the curve?
I can't stand a car that's doggy on the low end. I can't stand a car that has lousy throttle response. And a car that *has* to be downshifted to move is more like ricer territory, to me.
If I'm rolling down the freeway at 1800 rpm and I want to move around somebody, I don't want to have to downshift. That's why I have a V8. No, I'm not using full throttle, and hence the relevance to dyno runs is somewhat limited. But since the relatively crude chassis dyno is the only tool that is widely used, I'm trying to figure out what I want to know from that.
The other place where I need power relatively low is rolling through the mountains. I'm not going to run mile after mile in the mountains at 4k+. For one thing it will overheat, and for another I'd go deaf. But I also don't want to be shifting any more than necessary. This is driving for fun, not racing. So I pick a gear that keeps it between 2 to 3k as much as possible. Sometimes it drops a little lower for a slow corner. I expect crisp throttle response and good acceleration coming out of the corner. No, it won't be making peak power there but I can't use peak power in a lower gear there anyways.
For my purposes low and midrange is at least as important as top end. All I want is some data so I can compare different packages. Comparing a 206 cam to a 214 to a 224 doesn't tell you a lot if the graphs all start at 3k. If covering the gear drop is all that matters, those of us with 6-speeds don't have to worry about anything under 4k, so we all might as well run MS4s, right?
I wonder if GM does all their dyno pulls starting at 3k when they develop OEM cams?
