TT Truck Manifold Kit! (18psi)!
As alot of you know I have a 377 iron block with dart head's and a Truck manifold twin turbo kit!We finally got done with the tune after working out all the little bug's. At 18psi the car make's 922rwhp and 842rwtq!! I should be good for awhile!
http://www.atlpf.com/videos.html
http://www.atlpf.com/videos.html Last edited by HUNTER02SS; Aug 21, 2007 at 07:55 AM.
Fuel system consist of 2 bosch 044 fuel pump's. Fuel return setup ,with 60lb mototron injector's!-10 supply line to the rail's!
The video is up of the pull!
Originally Posted by Sam-eye-Am
WOW! That is some great numbers! Would you mind listing your fuel system componenets? I'm curious to know what all it took to support that kind of power.
Here is a pic of how the fuel pump's are set up.
Great numbers for sure!
Even though both pumps are "T'd" together into the single -10AN line it doesn't seem to be affecting flow one bit. I thought the preffered setup was to "Y" them together.
What is each pump rated at for flow/hp?
wow, i didnt know those 60lb injectors could support power like that...NICE!
how is the tq curve, is there a bit of hesitation and then a rush of power like most turbo cars?
Originally Posted by 93Polo
Sick man
I dug out those 18" Forgelines if you want to take a look at them
I dug out those 18" Forgelines if you want to take a look at themNICE you have a set of forgeline wheels too! I am running the not made anymore ls series in 18" and they are some sick wheels.
Sick man
I dug out those 18" Forgelines if you want to take a look at them Thread Starter
Originally Posted by HUNTER02SS
It's kinda like waiting,waiting,then bam,hang on!!!
Originally Posted by NemeSS
922rwhp with 60 lb. injecotrs?
are u using aeromtive fpr? and what p/n
is this with sd tune,?
