New N/A and N2O numbers
Old Sep 20, 2007 | 07:32 AM
blu1's Avatar
Originally Posted by Lneemup
Cam is stock its a 551/551 with 220/220 @.050.
I would redyno somewhere else, no way you made 415rwtq with your mods and that baby cam. 360-370tq sounds about right to me.
Old Sep 20, 2007 | 07:38 AM
Lneemup's Avatar
It was about 370 until I straightened the tune out. By the way we own the dyno and its accurate.
Old Sep 20, 2007 | 07:45 AM
blu1's Avatar
please post the dyno sheet, 368rwhp will not equate to 415rwtq I don't care how good the tune is. Maybe if you swap the hp and tq that would make sense.
Old Sep 20, 2007 | 08:28 AM
Lneemup's Avatar
Dyno sheet will be posted today at some point. If anyone would like to come to our shop and watch they are more then welcome.
Old Sep 20, 2007 | 11:29 AM
ATVracr's Avatar
Originally Posted by beardWS6
I spray 200 shot from 3200-6400rpms on my set-up! I was told by many never to spray in the 2000rpm`s, would Blow the motor up! Good luck!
They lied.
I spray mine at 1800 rpms.
Old Sep 20, 2007 | 11:56 AM
gator's 99TA's Avatar
Originally Posted by ATVracr
They lied.
big converter cars spraying at 1800 rpms means you are just spraying on the converter.
Old Sep 20, 2007 | 12:10 PM
Lneemup's Avatar
They lied.
I know they did. Some people just dont have a clue. Its load that is the problem not RPM.
Old Sep 20, 2007 | 12:35 PM
BADSZ28's Avatar
Right, too high of cylinder pressures will blow **** up. When you spray at lower RPMS, your creating MUCH higher cylinder pressures then higher RPMs. You are M6, you are loading the motor up at the RPM you hit the juice.
