Is this even Close To Right? 400w/ H/C/I
Old 10-01-2007 | 07:56 PM
98SS1LWEE's Avatar
Default Is this even Close To Right? 400w/ H/C/I
Okay, Had a tune Last Friday and Went to Get Some Dyno numbers today. Ended up at the Only Dyno In Town and It was a Dyno Dynamics. After Some issues, we pulled the car to 400.3HP and 367TQ at the wheels. First off, this was at 5800 rpms and they shut it down, cause the injectors maxed out. Tell me if this is even close to right. I've heard many say my numbers are way low, i shouldn't max stock injectors out til 500whp, etc....
400.3 HP 367.4 TQ
Stock bottom End with M6
243/249 .613/.615 109.5 LSA cam= TREX T-Rex
LS6 Stock 243's off Z06
Professional Products 86mm Intake
Stock, Ported Throttle Body
Stock 28.8 Injectors
Patriot.650 Springs, Tit Retainers, etc...
7.400" Chromoly Pushrods
Pacesetter LT's
TSP True Duals-Sweet Thunders
10-Bolt, Stock 3.42's(Got Lazy and Never got 4.10's put in
Any other info needed, let me know
A/F was at 12.7-12.9 area during pull
Really need some Help, Buddy has 02 with Torquer 2 and we're almost dead even, i pull him ever so slightly at top of third and so on, but still I have heads, Cam, Intake, Etc.. Shouldn't be equal to a t2 with bolt-ons at all
Old 10-02-2007 | 08:17 AM
98SS1LWEE's Avatar
please help!!!
Old 10-02-2007 | 09:29 AM
NOS USER's Avatar
Post the dyno graph .
Old 10-02-2007 | 12:45 PM
ONEBADWS6's Avatar
It is common for your injectors to be maxed at that power level, get some SVO 30lbs in the f.s section. Your intake is no better than a stock LS6, sorry. As for heads they are worth maybe 10hp over stockers when they are not ported. Is this a auto or M6?
Old 10-02-2007 | 03:01 PM
98SS1LWEE's Avatar
The intake, i know... But the heads. You saying 243's w/lightweight sodium-filled valves are only good for 10hp over stock 806's? And will the SVO 30lb'ers be big enough?
Old 10-02-2007 | 03:25 PM
98SS1LWEE's Avatar
First Run A/F was around 14 so richened it up to normal for second run. Still Soemthing's not right
Old 10-02-2007 | 04:32 PM
ONEBADWS6's Avatar
Flow #'s are flow #'s and unpored to unported there is not much difference. A svo 30lb is a 36lb injector on our cars. So you have a M6?
