what hp if I add heads / FAST to my TRaK cam only Vette?
My 01 A4/3200 stall/3.73 vette with a TRaK cam dynoed at 387rwhp. If I were to put on a set of good heads, what kind of power can I expect to make? What about a FAST 90/90 setup?
Well, according to the post below from Vengeance, if you go with their milled TFS215s and ported Fast90, you'll add about 67rwhp!!! I'd say a 7mph gain down the 1320 would be worth it ... if you have the dough. How fast do you want to spend? ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Note: I'm subtracting 5rwhp from their 72rwhp, because you're a C5 Z06 vs. a C6, with a stinkin LS2 vs. LS6 intake. And I'm assuming the TFS215s make as much as the LS2 larger bore TFS225s.
Later.
Later.
Good numbers man with that Stall and gears.
Get TSP PRC 5.3 and Mill them to 59cc and Ported Fast from Vengeance and that thing will be close to 430Rwhp maybe more and will get you close to 10s N/A For sure.
Oh and Congrats on the numbers I'm shoting for 420Rwhp with that cam and 64cc stg 2 ls6 Patriot in my M6 T/A.
