l92 engine dyno result.whats up with this thing?
my buddy took his truck to the dyno last night.here is what he has 02 z71 4wd with an 07 escalade l92 engine.ls7 cam long tube headers and true duals.he could only get 289 rwhp with 286tq.he is showing a cam sensor code but man these #s seem realy low.any suggestions?
The L92 is a variable valve timing engine. It has a special designed cam to work with the varying cam centerline changes. The LS7 cam is not designed with that in mind. That is most likely why the cam sensor code is popping up. Just a poor choice of parts and lack of research!!
LS1Tech Sponsor
Sounds like 2 issue's.One being the Cam signal and two is the dyno operator probly ran the truck in 2nd gear which will show lower #'s.
We run most trucks in second gear because the tires are rated for like 90mph and the driveshafts are rated at 120mph.I've had a few driveshafts litterally snap in 1/2 on trucks which breaks the transfer case and sometimes the tranny. A truck that revs to 6600rpm or so will hit 160-180mph in 3rd.
