*Help* Underpowered Torquer V.2 on 02 M6 LS1
Old Nov 6, 2007 | 12:10 PM
LastPewterZ's Avatar
Default *Now with Graph*Underpowered Torquer V.2 on 02 M6 LS1
It's been awhile since I've messed with it, but anyways here's the story. I have a 2002 Z/28 M6 that has an SLP lid, Stock Maf, Pacesetter LT's, ORY, March underdrive pulley, Borla Cat Back, Torquer V.2 cam 112 LSA, Comp 918 springs, Comp 7.350 pushrods, TSP ported oil pump, LS2 timing set, and pretty much stock everything else. With these mods (7.400 pushrods at the time) it put down a poor 366 whp/ and 370 something torque. This was on a dynojet and it supposedly had no more room to tune some more power out. A/F was right around 13:1 and it only received one count of knock. I've called TSP and they have no clue, I tried swapping out the pushrods which were the stock 7.400's and didn't really seem to gain much. I installed a cut-out and didn't see tons there either. It has not been re-dynoed since those two minor changes due to the fact that I'm very dissapointed. Could it have anything to do with the lifters? or the Maf? Idk what the hell to think. I'm probably going to end up taking it down to TSP next summer. Any thoughts or insight would be greatly appreciated.
Old Nov 6, 2007 | 02:05 PM
brad8266's Avatar
Pushrods should be longer than stock, something like 7.425 is moe like what you want.
Sure you arent down a cylinder or something?
Old Nov 6, 2007 | 03:43 PM
According to Dan at Dyno Sport here in Lincoln everything seemed to be running fine. The power curves and everything even followed a couple of other cars he'd dynoed with similar set-ups. The curves were lower of course, but...
Old Nov 6, 2007 | 04:01 PM
nick1ta's Avatar
how many miles? have you done a leakdown test?
Old Nov 6, 2007 | 04:34 PM
Patrick G's Avatar
LS1 Tech Administrator
M6 or A4? How does the tune look? What kind of timing at your torque and power peaks? Getting any knock retard on the dyno? What does your air/fuel ratio look like at WOT?
918s do not always give good valve control with fast ramps like the XE-R lobes in your V2 cam. 7.425" pushrods are the correct length with that cam. 7.350s are putting your pushrods at the very top of the plunger depth. If you'd post the graph, we might be able to see if you're having valve control issues. Answer the above questions and maybe we might be able to better help you.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Nov 6, 2007 | 05:20 PM
Jon@Texas-Speed's Avatar
I would start with a compression and leakdown test. If the heads have NOT been milled, then the 7.350" pushrods are too short. We have been running 7.400" pushrods with this cam forever and haven't had any problems with preload or valvetrain setup at all. What did the car dyno to begin with? A graph would definitely help if you can post one up.
Old Nov 6, 2007 | 06:06 PM
The car now has 42,000 miles on it. When I dynoed it with just the lid and catback it dynoed 321rwhp/333rwtq and had right around 35,000 miles on it. The motor is healthy, I could do a leakdown test but I don't think it has to do with compression. It was running a smooth 13:1 A/F as stated at WOT. As for the timing, it only recieved one count of knock and Dan said he didn't really wanna add any more timing because he didn't think it would yield any gains. I still have the Comp 7.400's, I guess I'll have to swap those back in. I'm gonna see if I can get the dyno graph from my tuner and I'll post it up.... I didn't even want it at the time because I was sooo frustrated
Old Nov 6, 2007 | 06:18 PM
litle88's Avatar
Is the cam degreed ok?
Do you have an adjustable timing chain?
Goodluck!
Old Nov 6, 2007 | 06:19 PM
It's not supposed to need degreeing. I just have the LS2 timing set. Thanks I'm hoping I get to the bottom of this before next summer so I can get out and play
Old Nov 6, 2007 | 06:26 PM
I forgot one thing, it's got a Jantzer ported throttle body too, I don't know if that would effect anything but anyways...
Old Nov 6, 2007 | 06:33 PM
Patrick G's Avatar
Graph would show whether you have valve control issues or not.
__________________
Old Nov 6, 2007 | 06:47 PM
^^ I'm working on it as we speak, I emailed him hopefully he emails me back by tomorrow at least
Old Nov 6, 2007 | 07:38 PM
litle88's Avatar
Sorry I meant if the valvetiming is on.
Old Nov 6, 2007 | 08:47 PM
^^ Hmmm, I'm not to sure what you're talking about. Fill me in
Old Nov 6, 2007 | 09:09 PM
Chris81's Avatar
Are you sure the cam was installed "dot to dot?" A tooth off can throw things way out of whack..
Did you do the cam nstall or did a shop do it?
We definitely need a graph to look at..
Old Nov 6, 2007 | 09:44 PM
MattIROC's Avatar
I put down 375/364 with the same cam through a 6spd w/ 4.10's, mac headers, hooker cb, stock 98 heads/ls1 intake, 26 degrees timing in 65 degree air. Your numbers arent too far off, but should be more than what I did with a better intake. My final a/f was 12:8:1
Old Nov 6, 2007 | 11:24 PM
It's not a tooth off, a buddy of mine and I did the install. He had done over 20 LS series cam swaps and he had me look at it to make sure. It's dead on dot to dot. Anyways, here's the graph but I'm not sure why it doesn't have a/f and all of that good stuff, I'll see if I can get a more in depth graph.
Old Nov 6, 2007 | 11:25 PM
Oh and one other thing, apparently for some reason my 02 has 853 head castings. WTF???
Old Nov 6, 2007 | 11:49 PM
litle88's Avatar
What!!!
YOU should have 241's!!
Did you buy it used? if so someone swapped them out.
Old Nov 7, 2007 | 01:19 AM
Demon Of Dreams's Avatar
my 01 put down 410hp/374tq with the mods in my sig + the Torquer 2 on 112 ...
if you've got those heads, I wonder what your intake is
