dyno runs on the 408
For your mods I think you make good power. I think your cam is a bit on the mild side for a 408 and some AFR heads would benefit you in my opinion. Autos are not dyno monsters...but they are great at the track with a nice stall.
Your compression is just right for a bigger cam...244/248 or something like that ( I am no expert), your exhaust set up looks awesome...(I should have true duals). What is it like with that converter and those gears ? It seems like 1st gear would be useless due to tire spin...you get decent traction?
Keep the updates coming.
don't know.
I too would leave the fuel alone for the spray. Gives you a good rich shot right when the nozzle starts spraying. It'll take up any lean out time due to the nitrous spraying ahead of the fuel for a split second.
As for the cam, I can see now the reasoning. I was wondering if it was only .551 with the 1.8s. Makes sense now. I understand about wanting it to be easy to tune. Props on doing it yourself.
at the suggestion of a member of another board, he said to retard the cam to make more power as his opinion is the cam being ground 5* advanced is limiting my peak hp at 5700 rpms. well, it didn't go as planned.
blue line = straight up
red line = 5* retard
You can see the updated numbers in my sig now. I have better heads, bigger cam and exhaust set-up. SD tune also!
526rwhp 482rwtq N/A
646rwhp 676rwtq unlocked !!this is on a 200 shot!
12-bolt, 3.73 gears nitrous tune and nitrous custom stall 3200
SD tune also! I have a ported fast 90-setup now! Not the Beck!
526rwhp 482rwtq N/A
526rwhp 482rwtq N/A
526rwhp 482rwtq N/A
either way, 650 rwhp is nothing to sneeze at. plus, you have better motor numbers than me.
#32
Your right, we locked the converter with my old fast 90 ported and got alittle over 220rwhp locked. Mike at G-Force just doesn`t like beating the conv on the dyno so he didn`t lock it ! Should put me over 700-725rwhp now! With my race weight at 3800 with me I`m hoping for 10.0`s!!!!!! I cut 1.5`s 60ft with my H/C and 100 shot! This is as heavy and pure street car as you will get!!
#34
I've seen alot of the "off" brand converters, so of them not so cheap, not stay locked on the dyno.
#35
I have a custom built Pro TRQ conv. Had it built with weight, power, shot size ect. Cost alot of money! I know I`m getting at least 200rwhp with the shot. Not worried! I can`t wait to see what my track times are going to be!! I hav a good set of ET drags just waiting to HOOK!!!
