stock dyno sheet anyone?
Old Nov 9, 2007 | 10:58 AM
tee-boy's Avatar
Default stock dyno sheet anyone?
ANyone have a stock 98' dyno sheet? Did a baseline of my car before mods and would like to compare it to others.
Old Nov 9, 2007 | 11:54 AM
John02Hawk's Avatar
Auto or manual trans?
Old Nov 9, 2007 | 11:59 AM
V8pwrdz28's Avatar
my M6 formula put down 324.9rwhp and 342.2rwtq stock.
Old Nov 9, 2007 | 12:42 PM
tee-boy's Avatar
Default m6
manual transmission.
Old Nov 9, 2007 | 12:43 PM
tee-boy's Avatar
Default fff
not really looking for peak numbers more interested in the curve.
Old Nov 9, 2007 | 12:49 PM
V8pwrdz28's Avatar
i have the sheets, but no scanner, oh well.
Old Nov 9, 2007 | 02:16 PM
edcmat-l1's Avatar
Say what? What kinda dyno? What correction factor?
Old Nov 9, 2007 | 02:43 PM
tee-boy's Avatar
Default Dynojet
That's a good question. I would be looking for a dynojet sheet for comparison if anyone has one. Thanks.
Old Nov 9, 2007 | 05:35 PM
bad6as's Avatar
well i dont have a dyno sheet on this comp but numbers in sig with mods in sig
Old Nov 9, 2007 | 10:04 PM
brad8266's Avatar
He wants stock dyno slips.
Old Nov 10, 2007 | 03:12 PM
bad6as's Avatar
or numbers of bolt ons to comapre
Old Nov 11, 2007 | 09:34 AM
ELMiN8oR's Avatar
Old Nov 16, 2007 | 12:34 AM
Chris Gage's Avatar
I have one, I have to find it though. My hp and torque were pretty nice, peak numbers were 338.6/351.8 with 160k+ miles on a dynojet, just a few ponies less on a dyno dynamics (337 RWHP @ 5650 rpm's
339 RWTQ @ 3250 rpm's). I will try to get my dynojet sheet scanned tomorrow.
NOTE - the graphs on each side are on a different scale
The car last dyno'd 309/304 with full bolt-ons, th400 w/4000 stall on a dyno that showed 30hp less then the dynojet listed above.
Old Nov 16, 2007 | 10:11 AM
JScamaro's Avatar
I don't have a '98 but it is a stock graph none the less.
[IMG][/IMG]
Old Nov 24, 2007 | 07:44 PM
tee-boy's Avatar
Default thx
wow. I appreciate your effort. Thanks.
Old Nov 24, 2007 | 08:51 PM
tee-boy's Avatar
I compared your stock dyno to my stock dyno. Both are dynojets at same latitude (Houston vs. Baton Rouge) and pretty close temps. Here are the differences..
RPM
Me
You
3500
205
211
4000
240
255
4500
267
287
5000
290
311
5500
300
318
6000
288
308
So I think my sig is right. My car is down on power. It doesn't look like I need the driver mod after all.
Old Nov 24, 2007 | 08:58 PM
tee-boy's Avatar
Default ddd
One more interesting mathematical fact... Your car is accelerating faster than mine. In other words, not only are the absolute HP numbers higher @ each rpm but the slope of your curve is steeper below 5250 than mine and flatter above 5250 than mine.
RPM Range interval Points
Diff in HP at interval points Me
Diff in HP at interval points You
3500/4000
35
44
4000/4500
27
32
4500/5000
23
24
5000/5500
-10
-7
5500/6000
-12
-10
My curve visually is a straight line from 3500-5000, whereas yours is concave over that same interval.
Old Nov 24, 2007 | 09:13 PM
bene's Avatar
Trunion King
Get rid of that flowmaster if its the 80 series.
Old Nov 25, 2007 | 12:24 AM
Hennytime's Avatar
i made 288/303 bone stock, unlocked auto
Old Nov 25, 2007 | 04:23 AM
JScamaro's Avatar
Keep in mind tee-boy I have an '02 which has better heads and a LS6 intake from the factory so it will have higher numbers.
If you still have the LS1 intake that is stock on the '98 replacing that with a LS6 intake will pick up lots of power on the top end.
Dumping that slowmaster for another catback or getting a cutout will help as well if you like the sound of the flowmaster.
