GM CNC L92 Head Results!
Old Nov 12, 2007 | 09:31 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Default GM CNC L92 Head Results!
Ok, we did a back to back swap on the engine dyno. The engine is our L92 427. We were running an L76 intake, box stock. The only change made between graphs was the heads themselves! We not only put the HP and FtLbs figures, but highlighted the difference between the runs in yellow for easier reference.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Nov 12, 2007 | 09:56 AM
WizeAss's Avatar
gained 27HP and 27TQ!?? Shaaaweeet!
What bore is the motor? and I assume the heads still have stock valves?
Old Nov 12, 2007 | 10:08 AM
It was a 4.068" bore, 4.1" stroke. And yes, this was a stock valve!
__________________
Old Nov 12, 2007 | 10:16 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Any hint of what they did below 4500 rpm? I know everyone is going to say that they never spend anytime at all below 4500 rpm because during drag racing it never goes below that, but I was just curious what they did at lower rpms.
Thanks.
Old Nov 12, 2007 | 11:09 AM
Patrick G's Avatar
LS1 Tech Administrator
Great gains. Was the combustion any smaller on the CNC heads (yielding a higher static compression)?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Nov 12, 2007 | 11:17 AM
No sir, they have the same size camber as the standard L92 heads!
__________________
Old Nov 12, 2007 | 11:35 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Awesome mid range gains, under the curve hp F T W!!
Old Nov 12, 2007 | 05:32 PM
WizeAss's Avatar
does your CNC program unshroud the valves at all? Also... that bore is considered pretty small. Standard 408 bore is 4.030 and standard 414 bore is 4.060 with a 4 inch crank stroke.
Makes it all the more impressive if the bowl was untouched near the valve. BTW, does your CNC program work more on the intake or the exhaust? Is this considered your top program or do you have a more intensive one?
Old Nov 14, 2007 | 09:19 PM
genmex's Avatar
Matt, are those numbers (cast hp) the ones from the 427 sent to Mty?
Old Nov 15, 2007 | 09:06 AM
We do not CNC these heads here...all of that is contracted by GM. It does not appear that much if any change has been made to the combustion chamber. This CNC head focuses more on the intake port than the exhaust for sure!
I'm not sure which 427 these tests were done on.
__________________
Old Nov 27, 2007 | 08:48 PM
texada's Avatar
What are the cam specs on this set up?
Old Dec 2, 2007 | 03:23 PM
Spinmonster's Avatar
Opening an intake runner usually has the effect of improving top end power especially with a big cam.. What it did to the bottom end with a 279cc runner is the real question. Can you post the lower numbers?
Old Dec 4, 2007 | 11:00 PM
Louis's Avatar
I agree Spin. The intake runner will hamper the driveability of the smaller cube stuff big time.
Old Dec 7, 2007 | 09:11 PM
WizeAss's Avatar
not a good choice for a street car looking for low rpm torque... yet with a nice NA converter for the strip.. or nitrous converter this should make some serious mph power for the track. who doesnt want a 4500 stall at the track?
Old Dec 10, 2007 | 08:46 AM
Sharpe's Avatar
+3 for 2500+ numbers...
