What do head problems look like on the dyno?
Here is the graph, Converter was locked btw:
Futral told me in a 383 with the F13 my power should be peaking at 6200 rpms, especially since I have a ported FAST 90/90 setup. What do ya'll think?
I used the stock length pushrods (7.400") and stock MLS head gaskets. I've been told that I might have too much DCR by my tuner. He said he thinks my heads might not be supporting that much flow, considering they are stock casting 5.3s and all. I'll be done with school for month after friday, so I'll have a little bit of time to check some things. Just don't know what to check first.
One more question? What is your exhaust system made up of?
The run in blue is through the full exhaust. The run in red is through the cut-outs.
I went from a 346 to a 383 and lost power everywhere. Plus the 383 peaked a lot earlier. I can't say that I would recommend a 383 stroker to anyone. Way too many disappointing results I've seen over the years on this website. Below is my graph. The higher curve is the numbers my 346 H/C put out. The lower curve are the numbers after installing a 383 stroker.
-Geoff
The cam could be installed off or maybe the cam was ground incorrectly. The setup should not peak that early, and even if it did should carry the power further.
Good Luck,
