Bolt-On's Only A4 351rwhp and 366rwtq
#41
A roller tip don't have to do that.
Now put your dick away. No one wants to see that little thang.
#42
No one wants to play swords with you because first, that's gay and second, you're just flat out wrong.
Honestly, you're trying to compare two totally different drivetrains. LS1 and LS2 GTO's have always made less power than their counterparts running the same motor/transmission combo due to the IRS, factory 2 piece drive shaft and less than stellar air intake design.
You're the one who seems to want to pull your dick out and start swinging it wildly at people, in the hopes of somehow starting a **** poor argument or in your mind, a discussion. Not only that but you thead-necro'd a discussion from over 10 years ago.
I didn't look at the dates when I made my post.
Actually, my point was that Dynojets' output are usually high. 350 on a dynojet is probably 320 on a mustang. Maybe the real number is somewhere in between? Wouldn't you agree that 40-50whp from his boltons is a little optimistic? Or, are you going to tell me f-body LS1s only lose 5% across the drivetrain?
#43
LOL
#50
Moderator
Received 1,838 Likes
Originally Posted by 06GR
What were the bolt ons?
Originally Posted by big hammer
Stock ls1 Cam and heads then everything else
#51
#54
Moderator
Everything you ever need to know about TB spacers:
https://ls1tech.com/forums/generatio...b-spacers.html
#56
