Need Some Dyno Sheets
Old Feb 13, 2008 | 09:46 AM
00ssmg's Avatar
Default Need Some Dyno Sheets
Hoping Someone Could Help Here....getting Ready To Purchase Cam And Converter And Just Was Hoping I Could See A Dyno Sheet On A 232/236 600 Lift 112lsa Cam Or Something Close To It Ill Be Running A 4000 Stall And Want To Make Sure Cam And Converter Match
Old Feb 15, 2008 | 05:40 PM
chrs1313's Avatar
should work perfect together...
here is a link with my 230/230 600 lift cam only dyno
https://ls1tech.com/forums/showthrea...&highlight=230
by the way i am swapping out my ss3600 for a ss4000 here in the next couple weeks
Old Feb 16, 2008 | 08:42 AM
offaxis's Avatar
I used to run that cam in my 01z28 . That cam matched with AS ported 6.0 heads made 430 rwhp with the ls6 intake. Add the yank PT4000 and a sticky set of tires alittle weight reduction and you are 10`s @ 12X all day long. Ill have to look at for the sheet onthat but I did have heads too so im not sure if thats what you were looking for.
Old Feb 18, 2008 | 08:47 AM
ExceSSive's Avatar
232/236 .617/.601 113.5
2000 SS M6, LS6 intake, and some bolt ons.
