GM ported ls6 heads and cam...
with the 60.9cc chamber and the GM Grand Am Cup Cam 239/251 570/570 106 spinning to 7200 rpms AND light wt rotating assembly ( not stock bottom end) Then YES 510-to 540 BHP is very possible.
The Speed World GT C5 corvettes used these
No it will not be a streetable head cam combo and is a bitch to tune
Still had the factory shut off on it.
Listen to the guys w/ experience. I personally have a hard time imagining you making 435whp (about 510hp) w/ a not so big cam, and those heads. I'm not diminishing the GM heads at all, but if they were the best out there, or even close, everyone would be using those instead of the rather expensive AFR's, TEA's, and TFS heads. I'd say AFR's and a good mid-range cam and you could see 435whp. Then again I'm no expert on the matter, but good luck regardless. I hope you prove all of us wrong w/ the GM stuff. Cause that means I could keep the mods in the family...
With a G5x2 it made 430/400(through 10 bolt/stock DS)
with a Trex it made 460/430(through 9" and 3" steel DS)
